When I try to click on Options, an error is thrown.
Can you tell me the error?
Also, for anyone reporting bugs, I suggest reading this: http://www.chiark.greenend.org.uk/~sgtatham/bugs.html
Telling me "it doesn't work" or "it throws an error" is unhelpful, you need to tell me what doesn't work and what error is thrown. Include all the text the the error. Take a screenshot. I can't fix something without any information.
This is what I see when I click on Options:
https://dl.dropbox.com/u/109591486/Capture.PNG
Can you copy-and-paste the error text ("you need to tell me what doesn't work and what error is thrown. Include all the text the the error.").
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at TokenIDE.Options.set_SelectedFont(Font value)
at TokenIDE.Tokens.optionsToolStripMenuItem_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.18010 built by: FX45RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
TokenIDE
Assembly Version: 0.10.3.0
Win32 Version: 0.10.3.0
CodeBase: file:///C:/Users/Daniel/Downloads/Tokens/TokenIDE/TokenIDE.exe
Win32 Version: 4.0.30319.18022 built by: FX45RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Microsoft.CSharp
Win32 Version: 4.0.30319.17929
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
Merthsoft.DynamicConfig
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/Daniel/Downloads/Tokens/TokenIDE/Merthsoft.DynamicConfig.DLL
System.Core
Win32 Version: 4.0.30319.17929 built by: FX45RTMREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Dynamic
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Dynamic/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Dynamic.dll
Anonymously Hosted DynamicMethods Assembly
Assembly Version: 0.0.0.0
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Merthsoft.Tokens
Assembly Version: 0.9.4769.36044
Win32 Version: 0.9.0.0
CodeBase: file:///C:/Users/Daniel/Downloads/Tokens/TokenIDE/Merthsoft.Tokens.DLL
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Merthsoft.Extensions
CodeBase: file:///C:/Users/Daniel/Downloads/Tokens/TokenIDE/Merthsoft.Extensions.DLL
Merthsoft.CalcData
CodeBase: file:///C:/Users/Daniel/Downloads/Tokens/TokenIDE/Merthsoft.CalcData.DLL
FastColoredTextBox
Assembly Version: 2.8.1.0
Win32 Version: 2.8.1.0
CodeBase: file:///C:/Users/Daniel/Downloads/Tokens/TokenIDE/FastColoredTextBox.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Thanks Daniel. By the looks of things I broke something in the fonts. I'll look into it tonight. Thanks for reporting this, GinD.
Glad I could be of some help, I'll wait on updating it on tifw until this bug is resolved Smile
Alright, this bug has been fixed. I've also added some token underlining into the Axe highlight file:
I only added it to the things that had black or grey colors. Obviously you can add it wherever you want.
You know the drill:
http://merthsoft.com/Tokens.zip
Cool cool!
Tokens keeps getting better and better.
OK, now it's working. I have no idea what's changed but now it's working.
No clue why it wasn't for a little while, I tried to run it from the commandline but going to the options makes it crash. I'll post the text below since that is something I can post.
The gtk warning thing is always there in _everything_ I ever use that uses gtk/logs thing to the console.
(<unknown>:6794): Gtk-WARNING **: Unable to locate theme engine in module_path: "ubuntulooks",
System.Collections.Generic.KeyNotFoundException: The given key was not present in the dictionary.
  at System.Collections.Generic.Dictionary`2[TKey,TValue].get_Item (System.Collections.Generic.TKey key) [0x00000] in <filename unknown>:0
  at TokenIDE.Prog8xEditWindow.UpdateHighlight (System.Collections.Generic.List`1 tokens, FastColoredTextBoxNS.Range range) [0x00000] in <filename unknown>:0
  at TokenIDE.Prog8xEditWindow.FullHighlightRefresh () [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) TokenIDE.Prog8xEditWindow:FullHighlightRefresh ()
  at TokenIDE.Options.set_TokenData (Merthsoft.Tokens.TokenData value) [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) TokenIDE.Options:set_TokenData (Merthsoft.Tokens.TokenData)
  at TokenIDE.Tokens.optionsToolStripMenuItem_Click (System.Object sender, System.EventArgs e) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripItem.OnClick (System.EventArgs e) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripMenuItem.OnClick (System.EventArgs e) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripMenuItem.HandleClick (Int32 mouse_clicks, System.EventArgs e) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripItem.FireEvent (System.EventArgs e, ToolStripItemEventType met) [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) System.Windows.Forms.ToolStripItem:FireEvent (System.EventArgs,System.Windows.Forms.ToolStripItemEventType)
  at System.Windows.Forms.ToolStrip.OnMouseUp (System.Windows.Forms.MouseEventArgs mea) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripDropDown.OnMouseUp (System.Windows.Forms.MouseEventArgs mea) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.WmLButtonUp (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ScrollableControl.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStrip.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripDropDown.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control+ControlWindowTarget.OnMessage (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control+ControlNativeWindow.WndProc (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.NativeWindow.WndProc (IntPtr hWnd, Msg msg, IntPtr wParam, IntPtr lParam) [0x00000] in <filename unknown>:0
Unhandled Exception:
System.ArgumentException: A null reference or invalid value was found [GDI+ status: InvalidParameter]
  at System.Drawing.GDIPlus.CheckStatus (Status status) [0x00000] in <filename unknown>:0
  at System.Drawing.Graphics.GdipMeasureString (IntPtr graphics, System.String text, System.Drawing.Font font, System.Drawing.RectangleF& layoutRect, IntPtr stringFormat) [0x00000] in <filename unknown>:0
  at System.Drawing.Graphics.MeasureString (System.String text, System.Drawing.Font font, Int32 width, System.Drawing.StringFormat format) [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) System.Drawing.Graphics:MeasureString (string,System.Drawing.Font,int,System.Drawing.StringFormat)
  at System.Windows.Forms.TextRenderer.MeasureTextInternal (IDeviceContext dc, System.String text, System.Drawing.Font font, Size proposedSize, TextFormatFlags flags, Boolean useMeasureString) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.TextRenderer.MeasureText (System.String text, System.Drawing.Font font) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripMenuItem.CalculatePreferredSize (Size constrainingSize) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripItem.GetPreferredSize (Size constrainingSize) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripDropDownMenu.OnLayout (System.Windows.Forms.LayoutEventArgs e) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.PerformLayout (System.Windows.Forms.Control affectedControl, System.String affectedProperty) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.PerformLayout () [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) System.Windows.Forms.Control:PerformLayout ()
  at System.Windows.Forms.ToolStripItem.OnParentChanged (System.Windows.Forms.ToolStrip oldParent, System.Windows.Forms.ToolStrip newParent) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripItem.set_Parent (System.Windows.Forms.ToolStrip value) [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) System.Windows.Forms.ToolStripItem:set_Parent (System.Windows.Forms.ToolStrip)
  at System.Windows.Forms.ToolStripItemCollection.Remove (System.Windows.Forms.ToolStripItem value) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripItem.Dispose (Boolean disposing) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripDropDownItem.Dispose (Boolean disposing) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripMenuItem.Dispose (Boolean disposing) [0x00000] in <filename unknown>:0
  at System.ComponentModel.Component.Finalize () [0x00000] in <filename unknown>:0
macarthur@laptop:~/Desktop/TokenIDE$ clear
macarthur@laptop:~/Desktop/TokenIDE$ mono TokenIDE.exe
(<unknown>:6800): Gtk-WARNING **: Unable to locate theme engine in module_path: "ubuntulooks",
(<unknown>:6847): Gtk-WARNING **: Unable to locate theme engine in module_path: "ubuntulooks",
There's that info there, but the other thing is working just fine now. No idea why it wasn't.[/code]
um
did you try it from the Windows command line?
or is this linux
That error only happens from the command line when using mono. So I guess it's mostly a non-issue. Since if I write a shell script that calls it, and tell it to just run, it works just fine. Thanks for this awesome tool
Huh, that's quite bizarre. It looks like it's having an issue with the XML file (specifically, it's saying there's a style used that isn't defined). Which XML file are you using? Did you modify it at all? What version of Mono and Linux?
I found a bug with how the Alt strings were handled, and have fixed it, download at the normal place:
Tokens is getting better and better!
I think a real cool feature would be an error checker. Like, if there was a way to have an xml file with a list of command tokens and their number of correct parameters and stuff.
That'd be incredibly cool but it'd also require loads more work in finding the number of parameters for each token and then implementing the feature in Tokens. If you, or anyone, wants to start a list with how many parameters are needed for each Token that would help get the process started!
I was typing a subscript L, but misspelled it as "|:", and Tokens said that the token wasn't found in the dictionary.
This is the ensuing error log:
http://pastebin.com/x30jK2bV
Hmm, I can't seem to reproduce the issue; can you post the full code you had at the time and tell me which tokens file you were using?
Here's a screenshot: http://snag.gy/Bgn4g.jpg
If I click continue on the error dialog, the window won't freeze but I'll get another error dialog a few seconds later, this time stating that the given key wasn't found in the dictionary as an unhandled exception.
Based on the lack of color on While, Disp and End, as well as the lack of a reference link in the bottom of the reference pane, I'd say you're using an old version. I can't reproduce this in the newest version. Please update and try again.
» Goto page Previous  1, 2, 3, ... 10, 11, 12  Next
Page 2 of 12
