Help! When I run MSD8x, it says "ERROR 0C00 A flash drive was not detected".When I run USBTools and goto the mouse demo, it says "ERROR 0C00" there too! But I have those things plugged in!
What OS are you running, and what version is it?
Directly to the calculator? Not both at once or through a hub, I hope? What specific adapter are you using?
- Jinnai
- Super-Expert (Posts: 818)
- 01 Oct 2012 02:05:31 pm
- Last edited by Jinnai on 01 Oct 2012 02:18:05 pm; edited 2 times in total
My OS is 2.55MP. My adapter looks like this:
[EDIT] here is a picture:
Well, google "mini USB adapter", mine is the last one on the right.
No URL for that? :/ I wouldn't be surprised if that OS was the problem, although I haven't heard anyone specifically complain about USB8x/MSD8x with the MathPrint operating systems. Well, google "mini USB adapter", mine is the last one on the right.
ben_g wrote:
Do you have both usb8x and msd8x installed?
What constitutes "installing"? They are oncalc.
Perhaps I need a new adapter.
Perhaps; that's why I was asking for the exact URL of where you purchased your adapter. 🙂
Well, I bought it on amazon for a few cents, free shipping. It's packaging was all chinese, if that helps. 🙂
ben_g wrote:
Is the mini-USB end of the adapter A-type or B-type?
Don't know which is which, but it is mildly T-shaped.
There should be an A or a B printed near the mini-USB connector. And if I'm correct, the inside of an A-type connector contains white plastic and the inside of a B-type one contains black plastic.
EDIT:
[img]https://encrypted-tbn2.gstatic.com/images?q=tbn:ANd9GcRlVcoepMe4r8MM7BwEWAeks-m6Uk1kYQ5PjBhsfrIY_uPyEFSs[/img]
EDIT:
That's why it doesn't work. It needs an A-type connector for the driver to know that the calc is hosting the connection. But don't worry, there iss a way to turn it into an A-type with some aluminium foil, but I don't remember the link..
That's not the problem; The problem is that the calculator can only host the connection if an a-type connector is inserted. But anyway, I found the trick to turn b-type into a-type:
http://ourl.ca/7646/142328
Oh, mackerel! I followed those instructions, and it works now! Bizzare (though understandable - still bizzare)! Now onto the next problems...
Excellent, I was going to suggest the A/B problem too. Nice catch, ben_g.
Indeed. Now we need to figure out why USB8x's mouse demo works for you, but Jerry and Doors CS don't seem to be behaving.
Will this adapter work for plugging a flash drive into the 84+SE, and all other USB applications?
If that is in fact a mini-A plug, as the page claims, then it should work fine. Register to Join the Conversation
» Goto page 1, 2 Next
Page 1 of 2
