So, how does the Zilog processor do division and square roots and stuff if it can only do AND functions?
The processor doesn't. It's all done in software.
I don't know about square roots, but as far as I know division is usually done a lot like long division by hand—a combination of shifting and subtracting.
GinDiamond wrote:
But doesn't the processor actually compute the numbers?
Yes, but it does much simpler operations than "take the square root of X". It can do addition, subtraction, bitwise and, or, xor, neg, and cpl. It can increment and decrement, push and pop to and from the stack, jump and call and loop. KermMartian wrote:
Yes, but it does much simpler operations...bitwise and, or, xor, neg, and cpl. It can increment and decrement, push and pop to and from the stack, jump and call and loop.
Right, and what is all that?
Take this for example. By hand, do the square root of 2. On paper. Your brain doesn't have a sqrt operation. You can add, subtract like a pro (I hope). Multiplication and division takes a bit more time to do. For the calc, it does long division. By using these simple operations, it is able to calculate these more complex math functions. Please look at wikiti for logs, sqrts, division, and more in assembly.
Note that the CPU has no idea what a floating point number is. It is all done in asm.
ben_g wrote:
It's actually quite ironic how the hardware of a calculator is really bad at math.
It's superb at math; it gets addition and subtraction operations right 100% of the time (as long as you don't throw gamma rays at it).
Also ironic is that the Casio Prizm uses a version of the SH4 CPU that has its FPU removed.
Well, They either had to deal with the marginal front-end costs of having the system programmer to write a virtual FPU, or the constant piece price of a more expensive CPU. It was most likely just more cost effective to get the FPU-free models. I'm sure Casio failed to foresee a flourishing 3rd party developer scene though.
Once I started poking in to z80 ASM, I started to see just how dumb and rudimentary it was. But, when you have a small background in Brainf***, you can easily see how the economy of commands can be harnessed to achieve grand things. If you could get a z80 core fast enough, I'm sure you could run Crysis
And FPU is the Float Processing Unit. It usually provides hardware support for manipulating floating point numbers. Common fixtures of the FPU are aritmetic (+, -, /, *) square roots, powers, and sometimes trig functions. The purpose is to drastically speed up a CPU's FLOPS (FLoating point number Operations Per Second). Doing anything to a Floating point number requires quite a bit of processing power, so an FPU can speed up countless aplications that ely on them.
In case you're wondering, a floating point number is just a representation of a number that can vary in precision. The alternative is integers which are "fixed point" and don't vary in precision. a change of 1 unit to a float could mean a change of 100, or even .001, in the number it represents. A change of 1 unit to an integer will always mean a change in 1 in the number it represents.
Thanks for the explanation of a floating point number, I really didn't know what those were.
Is there a way to physically add an Ethernet port to an 84+?
Man, you don't focus on anything for more than a few minutes, do you? You could, but making it actually do anything is a different question. Is there a way to physically add an Ethernet port to an 84+?
Man, you don't focus on anything for more than a few minutes, do you? You could, but making it actually do anything is a different question.Is there a way to physically add an Ethernet port to an 84+?
You're totally right. You should see how many game projects I'm working on at once! (about 20+, with all of the source codes up on the computer).
Anyway, back to the processor thing:
Could this processor work for the Ti-84+ if I replaced it with the native one?
http://circamicro.com/p-1517409-z8l18020psg-ic-20mhz-low-power-s180-64-dip.aspx
I don't see why you couldn't use a USB ethernet controller. Of course, you would have to write an ethernet driver (probably either the over-compicated RNDIS (ick) or a simpler standard CDC eth driver), a TCP/IP stack, and software to take advantage of it. Most of that software would likely need to be written as a Flash app due to its size (TCP alone could be several kB or more, and that's using a small implementation like uIP). Good luck.
The problem with the TI-84+ is that the CPU, RAM, the memory controller, and probably some other stuff is all in a single, proprietary ASIC. You'd have to replace all of those components, and at that point, you may as well build yourself an entire custom device.
Well, with the newest calculators, yes.
I still have tons of TI-83+s that have discrete z80s in them, and I'm actually going to experiment with cutting the RST line on one of them to see if I can then execute past $c000, something that Benryves suggested to me long ago.
Page 5 of 8
