I'm taking a C++ class with a not-so in depth professor. He's given us this assignment...
Write a C++ program which will ask the user to enter an integer from 1 to 15 and displays a number pyramid (implement input validation). For example, if the input is 4 the output will be as follows:
[should be centered]
1
2 1 2
3 2 1 2 3
4 3 2 1 2 3 4
The user input represents the total number of lines in the pyramid. Each number occupies three spaces. You must use nested loops to implement your program (Hint: Each line has three parts). You must prompt the user for the number of lines in the main() and then call a function called printPiramid() from the main that has the following prototype: void printPyramid(int numLines);
You should follow good programming practices (Program header, meaningful variable names, and adequate comments, proper indentation) while writing your program. If you do not implement the pyramid drawing function printPyramid(), you will not get credit for this assignment.
...and at first I was thinking I used the pyramid function to print the actual pyramid, but then when I was compiling it it said the function type was void, which I guess I should've realized on my own. Anyway, I'm not really sure what I should be doing from here.
#include <iostream>
int main (){
   std::cout << "Please enter an integer between 1 and 15." << std::endl;
   int numLines;
   std::cin >> numLines;
   std::cout << std::endl;
   if (numLines < 1 || numLines > 15){
      std::cout << "Incorrect value. Integer must be between 1 and 15." << std::endl;
   } else {
      void printPyramid(numLines);
   return 0;
void printPyramid(int numLines){
      for (int i = 1; i <= numLines; i++){
         for (int j = 1; j <= i; j++) {
            std::cout << " " << j << " ";
I mostly need to know what to do with this void function, and then how to also print the numbers out in ascending order on the left of the center column of 1's.
Without looking too deeply at your code to see any other problems, I can see you're calling printPyramid wrong--you only want the "void" for declaration. So, turn this:
   } else {
Into this:
   } else {
Hope that helps. If not, feel free to ask more questions.
Oh, ok! Yeah, that made the program actually run, but it won't print the pyramid out.
Does it print anything at all? Nothing, or an incorrect pyramid? Also, welcome to Cemetech, and please Introduce Yourself when you get a chance.
Just the pyramid won't print. And thanks, I will!
Ok, I ran it and got this:
[shaun@madigan programming]$ ./a.out
5
 1
 1  2
 1  2  3
 1  2  3  4
 1  2  3  4  5
So something is printing Smile As a hint I suggest thinking about adding another for loop.
Ok ok, I've got it working now except for this dealio.
3
 3  2  1
 3  2  1  2
 3  2  1  2  3
How can I make those extra digits disappear?
Here's just the printPyramid function.
         for (int k = numLines; k > 1; k--) {
            std::cout << " " << k << " ";
Also not related to the actual pyramid, but your input validation is correct only once. I can input an incorrect number twice and the program will quit.
When you print the first set of numbers, in between the spaces there's something there that you don't need to print Wink
Oh, thanks! I went ahead and fixed that.
If you mean the k, I do need it so it prints out the numbers on the left?
Think carefully about the bounds on your inner k loop. Think about what you want to be printing in each k loop, and how that compares to the j loop immediately following it. Remember, the k loop should basically be a backwards version of the j loop, just not duplicating the "center" number.
