Question, using the chart at the end of the btutor, is there a way to recall the characters using the hex table, within basic? (Without using asm, I mean...)
Install Symbolic on top of Omnicalc, then press Math twice. next copy all of the Symbolic functions to the homescreen in a row and hit enter. When you get a syntax error, select goto hit clear, 2nd-Entry, then put a quote in front and store to Str1. Next recall Str1 into a program and you are set.
