Hi,
The program MusicViewer, for TI-84+ doesn't work (for me). *SAD*
It gives an error at:
Code: :If K=/=0
:Goto D3
Maybe I need an other Program first to let it work fine.
If I change some things in the code, it still don't work, but that's probably my fault.
I hope someone can help me, because than I can easier make my music files.
Link to MusicViewer:
http://www.cemetech.net/programs/index.php?mode=file&id=326
Hopefully I can help.
What sort of error is it, exactly? Does it have a number and/or name?
Some things to specify:
What type of error was it?
Did you type it, or did you send it with a cable?
My initial guess is that you wrote "=/=" instead of "≠".
Have you tried MuseInc?
Even though it's not graphical as much (displays with C,D,E, etc), it's worth a try. You can download the latest version right here:
http://www.cemetech.net/scripts/countdown.php?/83plus/basic/MuseInc%20OR%201.3.zip&path=archives
Thanks for the replies.
After you asked what sort of error it was, I went looking what error it was. But I didn't get the error anymore. I can use the program again!
But, it wasn't as usefull as I thought, no insert of pauses and tempo.
So, now I'm making a similair program myself, I'll upload it soon.
Yeh, that's right, any 'alt'-code or something to easily make it?
Well, there is... Add the string "EnableHexNumpad" (value data: "1") under "HKEY_USERS/Control Panel/Input Method/" and restart your computer. Afterward, you're free to hold Alt and (with the numpad) type a literal plus followed by 2260.
Though, what I meant is that some users in the past have failed to recognize the "=/=" as one entity, and then endeavored to punch it into their calculators as three; if this were to be one of those cases, then it would have been case-closed.
Wait a second, you typed the program into your calculator manually? You should use
SourceCoder to do it. For the =/= (not equals) symbol, go to [2nd][MATH][2] on the virtual calculator.
No, I didn't type it, that would take to much time.
I downloaded it and used TI-connect to sent it to my TI-84+
I know that, for the =, ≠, >, < etc. I can do: [2nd][MATH].
I uploaded my program to make music.
You can check it out in: TI-83/84+ Basic>Media...
Here in the Cemetech archives? If not, you should upload it to our archives!
