I am working on the trouble shooting page on the DCS wiki, and since I have found a couple odd quirks that fixes bugs in DoorsCS 7.2 I would like your input of other odd fixes you have found. Mine is..
Note: This also fixes Omnicalc for some odd reason.
1 Run Inequalz or another conflicting application.
2. Run the application again and disable it.
3. Turn calculator off then back on.
4. Restart DoorsCS 7.2.
If this does not work, Do steps 1-2. and replace step 3 with:
3. Archive all programs you want to keep.
4. Remove batteries for 30 seconds.
5. Reinsert batteries and turn the calculator back on.
6. Restart DoorsCS 7.2.
I have found in my personal expedience that most DoorsCS problems are caused by the in-equals application which uses the same hook; therefore, it is best to avoid using the in-equals application when ever possible.
What are some odd fixes that you have found?
Also if you find any thing that can not be fixed using this method about, let me know, I will try to reproduce said problem and find a way to fix it!
