I am confused as to how to display special characters at specific locations. When using {18, X} in textlib, the character is always at (1,1) on the home screen. How do I change the cooridinates?
Have you tried the 15th command, called SetCursorPos, before displaying the character? According to the readme, the syntax is {15,row,column} for the list. Row can be from 1 to 10 and column from 1 to 26. I think this should work.
DJ_O is correct. Additionally, if you do Output( and then PutMap or PutC, it should display right after the text printed by Output(.
