Err, GCC can compile on extremely low amounts of RAM. Let's assume that you're using 16 MB on the nspire. Set the parameters gcc-min-heapsize to a little under 16*1024 (It's in Kb) and gcc-min-expand to 0, and that actually forces GCC to garbage collect any time it tries to use more than 16 Mb of Ram. Less ram makes it take longer, but it can compile it.
From GCC's Online Doc:
ggc-min-expand
GCC uses a garbage collector to manage its own memory allocation. This parameter specifies the minimum percentage by which the garbage collector's heap should be allowed to expand between collections. Tuning this may improve compilation speed; it has no effect on code generation.
The default is 30% + 70% * (RAM/1GB) with an upper bound of 100% when RAM >= 1GB. If getrlimit is available, the notion of "RAM" is the smallest of actual RAM, RLIMIT_RSS, RLIMIT_DATA and RLIMIT_AS. If GCC is not able to calculate RAM on a particular platform, the lower bound of 30% is used. Setting this parameter and ggc-min-heapsize to zero causes a full collection to occur at every opportunity. This is extremely slow, but can be useful for debugging.
ggc-min-heapsize
Minimum size of the garbage collector's heap before it begins bothering to collect garbage. The first collection occurs after the heap expands by ggc-min-expand% beyond ggc-min-heapsize. Again, tuning this may improve compilation speed, and has no effect on code generation.
The default is RAM/8, with a lower bound of 4096 (four megabytes) and an upper bound of 131072 (128 megabytes). If getrlimit is available, the notion of "RAM" is the smallest of actual RAM, RLIMIT_RSS, RLIMIT_DATA and RLIMIT_AS. If GCC is not able to calculate RAM on a particular platform, the lower bound is used. Setting this parameter very large effectively disables garbage collection. Setting this parameter and ggc-min-expand to zero causes a full collection to occur at every opportunity.
Also, I have an nspire, but since TilP hates OS 3.0, I may never be able to use Lua.
I can still do C though
