I want to keep the pop out of the Wait loop as that pop is for the full ExclamationLoopS' loop. The issue I am having is it is not reading the key press inside the Wait loop.
» Forum
> Your Projects
Fine, but you still need to pop that bc that you pushed, otherwise it's always going to crash. A second, non-flow-through label might do the trick, but in the meantime, the problem is that once you in from the keyboard port, you have to re-select a group due to the way the ASIC keyboard controller works. You can't assume the group will stay selected until you choose a new group.
Never knew that about the keypad thank you Kerm! It works the way i intended now wahoo!
Next step detecting the key input speed from the user and comparing it to the AI,
Fun! Fun!
Whats the eaisest way to invert the screen what I was told on irc confused me :/
Fun! Fun!
Oh look a update thingermabob! x2!!!
Yeah just added some new stuff and actually detect you hitting the keys and stuff
Seems like 30ish is about average speed. I wonder what people will get once its released. >.> <.<
Shows the screen that the game uses to yell at you for a false Twitch.
Also shows me getting a really good score at the end a 11 wahoo!
Triples!
Ok now I am in the need of sprites, The main part of the engine is done and all its just adding in phases and a few other things...BUT I need sprites first so.
Can I get some 16x16pxl sprites for enemies and 1 16x16pxl sprite for the actual player?
If some one feels like spriting the original Kirby characters that would be awesome as well
ScreenShot: shows every thing I have done so far
Yes you will have 3 lives so 3 false starts and start over...forgot to include that thanks for reminding me ^_^
Actually as many as you can make levels are definable in a pretty easy way now
Sorry for the devoidness of comments and repetive blatant copy pasting
In the original game each "draw" round you would fight some one else. so with that in mind I can happily put 5 people in each Difficulty and still make the difficulty progression doable (of which i realize is broken in that above example xD)
And I should probably comment that at some point....
EDIT:
Got most of it working now yay.
The reset button also works so now all I really need is More sprites xD
EDIT2:
Did not have a losing screen in that screenie so here it is!
EDIT3:
I hope no one takes these instructions literally....
Wait who am I kidding it makes it a lot more fun
Dif3:
ld a,3
ld (lives),a
ld hl,them1 ;game code starts here
ld bc,(20*256)+11
call alive
call go
jr nz,$-12
ld bc,(20*256)+8
call alive
call go
jr nz,$-12
ld bc,(20*256)+5
call alive
call go
jr nz,$-12
ld bc,(20*256)+3
call alive
call go
jr nz,$-12
EDIT:
EDIT2:
EDIT3:
I already drink lots of coffee, so I should do well here, right? Anyway, what other character sprite themes did you have in mind in addition to Kirby?
Any thing you can sprite up
I more or less went with the name twitch for that reason as I didn't want to blatantly abuse Kirby in this game So yeah what ever looks good in a 16x16 sprite xD
Releasing games is fun here is Twitch v1
Plans for the future:
Balanced difficulties
Calcnet support
Currently Implemented features:
3 difficulties
Lives
Score tracking
DownLoad Link:
http://www.cemetech.net/scripts/countdown.php?/83plus/asm/games/twitch.zip&path=archives
Calcnet support
3 difficulties
Lives
Score tracking
DownLoad Link:
does need more screenshots and thats cause when I was at "10%" it was more like "90%" of the actual engine and then I just needed content.
http://cemete.ch/p151410
If you look at the code there the "Call Go" jumps to the engine and then returns after following a bunch of other calls and jumps...kinda wacky how I did it and can probably be ridiculously optimized BUT i have no complaints with gfx its just over 2KB. ^_^
That could be replaced with a single loop or a lookup table, but it's not too bad as-is. I'm glad to hear that it is still a decently small program.
» Goto page Previous 1, 2
Page 2 of 2
