Are you using Text(5,5,"Test"), not Text 5,5,"Test"? There's a difference -- Text( (with parentheses) is like Output(, while Text (without parentheses) is like Disp.
Note that if you have constant coordinates you save a crapton of bytes by doing
As long as you are using that or Text(x,y,"text") I don't see what is wrong. You are either inadvertently clearing the screen somewhere else, or the repeat getkey is reading a keypress too fast for it to loop the grayscale properly (try repeat getkey(15) maybe to continue only on hitting clear)
Text(y*256+x)
Text "text"
hi there
Shakespeare's Comics-My Webcomic
I got a question: How do you display a pic in ram to the screen?
I have this code:
Well, it doesn't display pic1......
I have this code:
:.AA
:[Pic1]
:DispGraph
:getKey{r}
Well, that doesn't work, but I found out a other solution:
Still thanks!
[PIC1]->A
Copy(A,L6,768
DispGraph
souvik1997 wrote:
Try doing this:
[Pic1]->Pic1
Pic1->DispGraph
Newer Axe versions have changed the syntax for that operation, it is now like this:
[Pic1]→Pic1
DispGraph(Pic1)
Yeah, syntax changed. PTR→DispGraph is now DispGraph(PTR). And Sorunome, use
instead. GDB1 is a contant number, unlike A which is a variable.
If you just want to display the image and not do much else with it, use DispGraph(GDB1).
[Pic1]->GDB1
Copy(GDB1,L6,768)
DispGraph
Ashbad
- Guru-in-Training (Posts: 2497)
- 27 Oct 2011 04:29:49 pm
- Last edited by Ashbad on 28 Oct 2011 06:42:36 pm; edited 1 time in total
spud2451 wrote:
i gots a question... How would you join X+", "+Y into Str1
Well, since unless the the >Dec routine has changed into returning a pointer to a string representation of a 16 bit int, you'll need to first have a routine that converts from int to string, I'll try to whip one up on the spot:
Lbl ITOS
r2+4->r2
r1^10->{r2--}
While r1
/10->r1^10->{r2--}
Str2-4
Return
Takes a pointer to a memory chunk to use for the output string, returns the original pointer for ease of use with HL pipelined code. Now to concatenate with that is pretty darned easy:
" , "->Str1
ITOS(X, Str1)
ITOS(Y, Str1+7)
I mean, I haven't worked with Axe for a while so there could be a better way around it that was recently added; but I don't like poking my head into it's API anymore so this is all I can offer.
Thanks ashbad and now i have another question... How do you display the token given by input as text?
Well, input first of all yields an allocation with the last input text, so first you would capture it in a variable or something similar. Then you could run through the returned token string and find the length, and use it sequentially print out each token and check if it's one or two bytes, and then advance the index pointer by the needed amount. This routine I'll whip up on the spot (again) should do it, taking for it's parameter the pointer to the token string to print, and has a void return type:
Lbl DRTOK
While
1
Disp r1>Tok
{++r1+not(inData({r1},[5C5D5E6061AA62637EBBEF]))->r1}·eFF00
Return
I can't test it, but it should work. Please tell me if you don't understand this or the previous one so I can walk you through how it works.
EDIT: and here'show you could invoke that:
DRTOK(input)
Hey I want to make sprites with grayscale larger than 8x8. How would I start? Also I need help with animation. Thanks
Enigma
Enigma
To draw sprites larger than 8x8 pixels, you need to either use the Bitmap() command or break up your sprite into multiple 8x8 sprites and draw them with PtOn(), PtOff(), PtChange(), etc. You would draw one layer onto the main buffer and the other layer onto the backbuffer, and use either DispGraph^r or DispGraph^r^r.
Enigma wrote:
Thanks for the tip but I was just wondering about speed.
?? Didn't you just ask about how it would work, rather than how fast it would take? (at least, I think that's what I think you mean when you say what you're now)...
... but concerning speed, the Pt-On command is rather fast (read: fastest you're going to get), but the Bitmap one is quirky and slow, so try to use Pt-On whenever possible.
Oh, sorry Ashbad if that's what you thought I meant. I meant out of all those methods which one would be the fastest but I have decided to go with the Pt-On method. I've found a way to do large sprites in hex. Thanks
Enigma
Edit: OK, Now I have another question. How do you do animations in Axe?
Enigma
Please don't double post. If you have something you want to add, and it hasn't been 24 hours since your last post (if yours is still the most recent post), just edit your last one. The edit button is to the top right of your post when reading the topic.
That said Animation is a large subject that encompasses lots of techniques. The easiest that doesn't involve Line( is to use two or more sprites, and write them at the same place, in order, on the screen, with a DispGraph between each drawing.
Page 8 of 12
