According to the documentation,
mpz_fdiv_q_ui
should round down. However, when 1298 is divided by 62 (20.93), it rounds up to 21. Help anyone?
thanks,
toraora
GMP documentation wrote:
Function: unsigned long int mpz_fdiv_q_ui (mpz_t q, mpz_t n, unsigned long int d)
@ifnottex Set q to n/d, rounded towards -infinity.
I can't say I have any idea why that's happening. What is the code for your use case?
I am converting base 10 number (encode) into a base 62 number.
for (int a=counter; a!=0; a--)
mpf_div_ui (sub_mpf.get_mpf_t(), encodef.get_mpf_t(), int (pow (62, a)));
sub = floor (mpf_get_ui (sub_mpf.get_mpf_t()));
mystring = mystring + base62.substr(sub,1);
mpf_sub_ui (encodef.get_mpf_t(), encodef.get_mpf_t(), sub * pow (62, a));
cout << "\n" << sub << " " << mystring << " " << base62[sub] << " " << a << " " << encodef;
edit: the cout line is there so i can see what the program is doing
edit2: i have changed mpz to mpf, but same thing happens
Hmm, I see no glaring errors in that code. You of course cout'd the operands to make sure everything is as you expect, right?
