This is some code I have in Ti-Basic. Sorry for some bad characters that were "changed in transition" to this forum.
ZoomSto
"="->Str9
0->A
0->B
0->X
16->Y
0->C
0->K
int(KORHALIV
Lbl UA
60->Ástep
ë^(B,A,Str0,0
60->Ástep
ë^(Y,X,Str9,4
int("DD
getKey->K
If Kø0
Then
K->C
If K=24
">"->Str9
If K=25
"+"->Str9
If K=26
"Horiz"->Str9
If K=34
"Polar"->Str9
If C=24
Then
X-4->X
If X<0 and Aø0
Then
80->X
A+96->A
X+4(X=-4)->X
If Str9="="
Then
">"->Str9
Else
"="->Str9
Goto UA
If C=25
Then
Y-4->Y
If Y<0 and Bø0
Then
48->Y
B+64->B
Y+4(Y=-4)->Y
If Str9="Horiz"
Then
"Func"->Str9
Else
"Horiz"->Str9
Goto UA
If C=26
Then
X+4->X
If X>80 and Aø864
Then
0->X
A-96->A
X-4(X=84)->X
If Str9="="
Then
">"->Str9
Else
"="->Str9
Goto UA
If C=34
Then
Y+4->Y
If Y>48 and Aø576
Then
0->Y
B-64->B
Y-4(X=52)->Y
If Str9="Func"
Then
"Polar"->Str9
Else
"Func"->Str9
Goto UA
Goto UA
Str0 is 2400 characters long, so naturally the program is slowing down little by little and does not stop slowing down. Is there a way to fix this assuming I'm using a parser? Otherwise, if I work with a bunch of smaller strings, will that fix the problem?
Just as I suspected, you have a giant mass of memory leaks. Every time you Goto out of an If/Then/End, For/End, While/End, or Repeat/End structure, you leak memory. I'm surprised you got as far as writing an ASM tutorial without discovering TI-BASIC memory leaks. Smile It has nothing to do with the sting, though.
Now you know why I'm not very good at Ti-Basic 0_0
Edit: What about this one? I don't know what would cause a memory leak here, but it's apparently happening again
ZoomSto
"="->Str9
0->A
0->B
0->X
16->Y
0->C
0->K
int(KORHALIV
Lbl UA
60->Ástep
ë^(B,A,Str0,0
60->Ástep
ë^(Y,X,Str9,4
int("DD
getKey->K
If Kø0
Then
K->C
If K=24
">"->Str9
If K=25
"+"->Str9
If K=26
"Horiz"->Str9
If K=34
"Polar"->Str9
If C=24
Then
X-4->X
If X<0 and Aø0
Then
80->X
A+96->A
X+4(X=-4)->X
If Str9="="
Then
">"->Str9
Else
"="->Str9
If C=25
Then
Y-4->Y
If Y<0 and Bø0
Then
48->Y
B+64->B
Y+4(Y=-4)->Y
If Str9="Horiz"
Then
"Func"->Str9
Else
"Horiz"->Str9
If C=26
Then
X+4->X
If X>80 and Aø864
Then
0->X
A-96->A
X-4(X=84)->X
If Str9="="
Then
">"->Str9
Else
"="->Str9
If C=34
Then
Y+4->Y
If Y>48 and Aø576
Then
0->Y
B-64->B
Y-4(X=52)->Y
If Str9="Func"
Then
"Polar"->Str9
Else
"Func"->Str9
Goto UA
Tanner: Don't double post, please Smile
If you don't mind, could you use SourceCoder and convert the program then use the BBCode text and repost it? Some of the things it is cutting off are important imo
Definitely this. It's very hard to read in that format. It would be especially good with indentation turned on.
