What is the most important thing you want in a TI-BASIC program?
Size
 0%  [ 0 ]
Speed
 50%  [ 3 ]
Usability
 50%  [ 3 ]
Total Votes : 6
BASIC Code wrote:
:Lbl A
:ClrHome
:Disp " WEIGHTAGE FOR:",""
:Input "QUARTER: ",A
:Input "FINAL: ",B
:If 2A+B≠100
:Then:Goto A
:Else:Goto B
:Lbl B
:Menu(" CALCULATE:","SEMESTER GRADE",1,"MINIMUM GRADE",2,"EXIT",3
:Lbl 3
:ClrHome:"
:Return
:Lbl 1
:ClrHome
:Disp "INPUT GRADE:"
:Input "QUARTER 1: ",C
:Input "QUARTER 2: ",D
:Input "FINAL EXAM: ",E
(A/100)(C+D)+(B/100)E)→θ
:Disp "","SEMESTER GRADE",θ
:Goto AA
:Lbl AA
:If 90<θ
:Then:Disp "AWESOME:A"
:Else:Goto AB
:Lbl AB
:If 80<θ
:Then:Disp "AVERAGE:B"
:Else:Goto AC
:Lbl AC
:If 70<θ
:Then:Disp "WORK:C"
:Else:Goto AD
:Lbl AD
:If 60<θ
:Then:Disp "BAD:D"
:Else:Goto AF
:Lbl AF
:Disp "HORRIBLE:F"
:Goto B
:Lbl 2
:ClrHome
:Disp "INPUT GRADES"
:Input "QUARTER 1: ",G
:Input "QUARTER 2: ",H
:Disp "WHAT PERCETAGE"
:Input "DO YOU WANT? ",Q
:If Q<0
:Then:Goto 2
:Else:Goto QQ
:Lbl QQ
:Disp "","MINIMUM GRADE"
(Q-(A/100)G-(A/100)H)/0.2)→Z
:Disp Z
:Pause
:ClrHome
:Disp "QUESTIONS ON"
:Input "FINAL: ",N
:ClrHome
:Output(1,1,"MINIMUM PERCENTAGE FOR:"
:Output(4,3,Q
(1+int(log(Q)→T
:Output(4,4+T,"PERCENT IS"
:Output(6,3,(Q/100)N
(Q/100)N→W
(1+int(log(W)→U
:Output(6,5+U,"QUESTIONS"
:Pause
:Goto B
Generated by SourceCoder, © 2005-2010 Cemetech
Is this a beneficial program. In Lbl A I ask for the weightages. Is there a way for me to save the weightages so that the user wont have the enter them each time he/she uses the program?
You could save it to a custom list.
:If 90<θ
:Else:Goto AB
:Lbl AB
:If 80<θ
Umm, what? You don't, but any means, need that goto. Unless it's supposed to be a way to slow it down? For me, speed is always a great thing I look for. You could try some methods of using lists that seem to work pretty well, I'll post some code if you'd like to see an example.
_player1537 wrote:
:If 90<θ
:Else:Goto AB
:Lbl AB
:If 80<θ
I tried to just say:
:If A>90
:Disp "AWESOME:A"
:If B>80
:Disp "AVERAGE:B"
But this didn't work so I used Goto. How I can get rid of this? Isn't a custom list only for saving number?
Yes, but A and B are both numbers as well, so it would work. One method you could try is:
SetupEditor lBENEF
6->dim(lBENEF
If lBENEF(1) != pi
Then
pi -> lBENEF
<input numbers and store them to the appropriate spots in lBENEF>
<continue normally after lBENEF's elements are stored in the right variables>
Just a note for the quiz: I want a balance of the three. For a game, I want an emphasis on speed. For a utility, I want the emphasis on size.
SetupEditor lBENEF
6->dim(lBENEF
If lBENEF(1) != pi
Then
pi -> lBENEF
Player I am a little confused. How do I input values and store them into the list and why is the code saying:
[/code]If If lBENEF(1) != pi
Why are you using factorial and pi?
rohi89 wrote:
SetupEditor lBENEF
6->dim(lBENEF
If lBENEF(1) != pi
Then
pi -> lBENEF
If lBENEF(1) != pi
"!=" is the equivalent of the not equal (=/=) sign on the calculator. It's what you'd use in most computer programming languages. (There is no ASCII equivalent for the =/= sign.)
