here is a good was to deal with highscore appvars:
place this at the beginning of your program:
this first checks to see if appvNAME exists in RAM. if not, it attempts to unarchive appvNAME. if it is not found in the archive, the appv is created and made [desired size] bytes long. the pointer to the beginning of appvNAME is stored in theta, so accessing/storing is as easy as {θ+[n]} or S→{θ+[n]}
at the end of your program simply add
:Archive Str1
for safe-keeping
:"appvNAME"→Str1
:GetCalc(Str1)→θ
:!If θ
:UnarchiveStr1
:GetCalc(Str1)→θEnd
:!If θ
:GetCalc(Str1,[desired size])→θENDthis first checks to see if appvNAME exists in RAM. if not, it attempts to unarchive appvNAME. if it is not found in the archive, the appv is created and made [desired size] bytes long. the pointer to the beginning of appvNAME is stored in theta, so accessing/storing is as easy as {θ+[n]} or S→{θ+[n]}
:Archive Str1
for safe-keeping
