Yes, calculator symbols, are all of them, PC programming languages only have a few....
Sooo, any progress on this? I'm somewhat confused why the scripts that that user presented aren't working for you, and I'm interested to hear further debugging results. KermMartian wrote:
Sooo, any progress on this? I'm somewhat confused why the scripts that that user presented aren't working for you, and I'm interested to hear further debugging results.Well, the other guy's scripts are not working. If they were I would make it Graphical User Interface, update it and release a way better one!
I managed to remove the ASCII Characters bug, check this:
http://www.python-forum.org/pythonforum/viewtopic.php?f=18&t=22312
If I can't make this work, I'll move to C# :S
To answer the question that you asked on that forum, when it says "command window", in means the IDLE window that you just opened two steps previously. Also, I don't think adding a GUI would make it "way better" personally, as I prefer CLI programs for speed and simplicity, but to each his own. Also, if you do do that, be sure to credit the relevant parties for their assistance and code.
Of course, I always credit contributors! I'm not a thief!!!
I would make it better because if I could make it work, a text editor would convert the programs
I did open IDLE, and inside IDLE pressed Open and opened the file, then in the idle command, I wrote the code for compiling and recompiling:
recompile ('D:\...','D:\...')
decompile ('D:\...','D:\...')
I don't think anybody could make it work, by the way, in the program's page other people are blaming
Ah, if you had a text editor converting the programs (similar to how SourceCoder works, I guess?), then that would indeed be easier. MY only concern would be if someone prefers a different text editor, for example Notepad++. Indeed, if you could make some kind of macros so that Notepad++ could recompile plaintext source to .8xps, that would be very cool. Finally, I feel like you're channeling Richard Nixon with the first line of your post. Forgive the mistaken implication, I don't think you would fail to credit the original author.
Who is RIchard Nixon? The creator?
http://en.wikipedia.org/wiki/Richard_Nixon
Richard Nixon! Now that makes some sense!!!
Now, I may be moving to C#, any recommendations?
Merth's Tokens is C#. I would prefer to make a team with him and help him out, but he refused it already.
So, I can ask him for help on making my own one, right?
merthsoft wrote:
Are you asking me to help you write a competing application?
Not sure if you noticed, but this is for learning purposes, I don't plan to upload it. In fact, only me would use it, if I do.
Let me explain:
-I'm learning C# and writing one would be cool to learn;
-If it gets cool, I will use it personally, since it would be scoutdavid-friendly and otherpeople-unfriendly;
-No, I don't plan to compete, since as you already know I really like Tokens and use it.
Well, I would certainly not refuse to answer any questions you have about C#, so ask away benryves and sircmpwn are also C#'ers, so I'm sure they can help as well.
!!! SirCmpwn! He can help me lots, I think he's professional at C#, actually and I am in a C# Project with him, tiDE.
The only question I have a.t.m. are bytes, like in Python I would have
finalbytearray = bitearray()
# then for each token I would have finalbytearray.append(0xde)
Thus, I can create a byte 'variable' which will be the final file.
For each token found, it appends 0xde, 0xdd, according to the token to that array.
How can that be done in C#?
I find it easiest to start with a List of bytes and add them:
And I am a professional C# developer; not that that necessarily makes me good (;
List<byte> byteList = new List<byte>;
byteList.add(0xde); // or whatever
That's what I do in python too, create a list and then add.
Thanks much, that piece of code is very useful!
The python matcher for the text (the engine that finds the tokens, like "Disp ", and "Prompt ", and "Pause " and the letters and nums like "H", "4", "7"; was the hardest thing to make, well, in fact, I never made it.
You can give me some advice or a piece of code or anything concerning this subject. However, it will be easier to find info on tokenizers in C# than in Python
He's not a professional anything; he's a high school student. Merth gets paid megabucks for professionally writing C#, so I'd certainly hold his skills in high regard.
I'd still recommend the maximal substring matcher, even with C# as your language instead of Python.
He's not a professional anything; he's a high school student. Merth gets paid megabucks for professionally writing C#, so I'd certainly hold his skills in high regard. Quote:
This is basically what I do. You can do it with a hash table, though mine's a little more complex. merthsoft wrote:
This is basically what I do. You can do it with a hash table, though mine's a little more complex.Register to Join the Conversation
Page 6 of 8
