Hey,
So, I'm trying to make a 8xp to txt, just like Tokens or SourceCoder, to learn, though, not to use it, to learn more
So, i'm gonna need tokens:
http://omnimaga.pastebin.com/3KQ3PRFe
I'll use this ones.
However, I have no idea what kind of knowledge I need to use the things in front of the tokens:
Code: tDisp EQU PROGTOK+16 ; DEh 'Disp_'
How could I implement this in a program, for example?
I'll probably give up after making the Disp one, so I have to make sure I can do it.
I'm gonna be using Python, but I don't need help with Python, I need help on what I should use in the program from that line tDisp above?
DEh, or $DE, is DE in hexadecimal, or 16*D+E in decimal. D is 13, E is 14, so it's 16*13+14 = 222. Therefore, you'd insert a byte with value (decimal) 222 or (hexadecimal) $DE when you want to add a "Disp " token.
That's not english, that's some kind of language I can't understand, hah
ScoutDavid wrote:
That's not english, that's some kind of language I can't understand, hah Ah, so the problem is that hexadecimal is not something with which you're familiar. 🙂
http://en.wikipedia.org/wiki/Hexadecimal
And in reference to your PMs:
[19:56:51] <ScoutDavi> My program should read the code, and change each token (Disp, DispGraph, Pause, ClrHome) for their equivalent in code or it should look for each token and then check which are there and 'translate' those ones?
[19:58:08] <KermM_> hmm
[19:58:16] <KermM_> you're going text to 8xp
[19:58:38] <KermM_> so you need to turn the five-byte string "Disp " into the one-byte value $DE
[19:59:04] <ScoutDavi> Yes
[19:59:21] <ScoutDavi> Oh and I have the problem with L1 L2 L3 L4 L5 Pic1 Pic2 Pic3 Str1 Str2....... still
[19:59:22] <KermM_> let's post in the topic
Okay, I skimmed through that article 'cos I know what hexadecimal numbers are and I can make calculus with HexaDecimal numbers too.
def find_disp(text):
if 'Disp' in text:
finaltext = "$DE"
def find_prompt(text):
if 'Prompt' in text:
finaltext = finaltext+"$DD"
The Python syntax is not 100% correct, but I think I need to make sth like that.
text is the .txt given by user and final text will be the .8xp text
So far so good, except that it's 'Disp ' and 'Prompt ', not 'Disp' and 'Prompt ' (the space isn't a separate token). also, this seems like a really, really space-consuming way to code it; you'll need millions (well, about 680) def's.
Kerm, I'm already managing a few things, quite cool, I will do about 680 def's, OF COURSE NOT, I'll use database to check it, but this is just a first attempt.
Let's suppose the program
Code: Disp "A
Would be
$DE$2A$41
Now, I get this in the final text variable.
If I save
$DE$2A$41 as a .8px it will run Disp "A?
Well, there's also the header (maybe 56-odd bytes) and the 2-byte checksum. 🙂
TI BASIC files need headrs in teh .8xp? How are they made?
What's a checksum?
http://codepad.org/rcWlBCx1
Working ;D
The space after Disp not working, though :s
Working ;D
That's because you're splitting on the " " [space] character. When you split on a character, that character is removed. Splitting "1,2,3" on the comma character yields the list ["1" "2" "3"], for example. Tokens are all different lengths, and most are not separated by anything; for example, the strings "Disp ", "32Ans", and "3(-A)" are all five characters, but one, three, and five tokens respectively. You'll want to do some kind of maximal substring matching, which just so happens to be what I do in SourceCoder.
$DE isn't a string, it is a 1 byte value. You need to actually write a byte with the value of $DE.
So if you are using a newer version of python, you'll want a bytearray.
Code: buf = bytearray()
# ... do some stuff, find some tokens, whatever
buf.append(0xde)
buf.append(0xde)
Ouch, I didn't even notice that he had done that; thanks Kllrnohj. While we're on the subject, I find Python's handling of byte arrays and related byte-based structure handling way, way more awkward than it needs to be, and writing a script that works properly on both 2.7 and 3.x (namely BinPac8x) is an exercise in migraines.
Hey, really sorry to interrupt but this link can do the same thing...
http://ti.zewaren.net/en/
I mean good idea and all but I think its already been done.
😁 Well, of course SourceCoder 2.5 can already do the same thing six ways to Sunday, and has been doing so for about six or seven years now, but I got the impression he just wanted some experience with the token set and with Python. 🙂 Also, Merth's upcoming Tokens program attempts a client-side program with the same functions.
Okay,My bad! I'm sorry, I thought that the converter was just meant to be like a replacement or something.
No worries, I had the same initial reaction until he explained that he was familiar with both SourceCoder and Tokens and was doing this for the experience. 🙂
yup, to learn! (not python, .8xp file making)
Ok, I started to try to do a substring matching, with no luck
buf = bytearray()
buf.append(0xde)
Also, thanks for that, I knew that but didn't remember.
I'm still having wtf issues with checksum and headers, but i tried editing .8xp files to learn them 😁
So, while studying .8xp files, I tried this:
Code: :Disp "Hello World
Turns out this:
buf.append(0xde)
Now this,
What should buf be (input text or final text or split input text)?
0xde, what is that?
Thanks in advance and sorry for douple posting
0xde = $DE = 222d = %11011110 = "Disp ". Viewing the file in a text editor (looks like Notepad++ to me) isn't going to help; you need a hex viewer slash editor. I strongly recommend XVI32:
http://www.chmaas.handshake.de/delphi/freeware/xvi32/xvi32.htm
