Im trying to add 500 to the players health (A) if the player wins the current battle. like say 1XX+500=6XX. ?
Anywho, Choice 7 is done. Will upload to site later.
Soo, just If (conditional for winning):A+500->A ? That's all you'd need...
So just
If:A+500->A
next fight
A+500->A:XXX->B?
like 500 or 849 or something like that.
Is it a variable or a constant?
adamac15 wrote:
constant (i think)
A variable is something that changes, like the variables A to _theta_ and lists. A constant is a fixed value that doesn't change. If you are using a constant you wouldn't need XXX, you would need the constant. 🙂
its the opponents health. every opponent start out at 1000 health.
Then you are referring to a variable, not a constant.
So instead of XXX->B, you would do C->B, or D->B, or E->B etc. You would use the variable where you are storing the value you want to put into B.
i understand that, but would i have to do that for A's health?
I don't think so... Does XXX affect A in any way?
no. actually i dont know why i said XXX. (B's health.) guess i wasnt thinking.
Ill post the code later. For clarity. And so you can actually see what im talking about.
If B is the enemy's health, and you have to reset the enemies health to 1000 for each match, then A+500->A:1000->B would do the trick.
i tried that with 1 (shortening the health till i figure this out) and it resets the next battles health to 500 instead of 501.
Hmm, what do you mean? Can you post the code in question that has this behavior?
Ill post it when i get home (at school atm and i dont have enough time to manually type it in)
That's fine, take your time. I am concerned that you perhaps have less firm of a grasp on the fundamentals of TI-BASIC than is ideal, though; perhaps we can work on that at some point.
