I watched a video recently about an alternative to studio lighting. But that's not the point. The point is that the light reflected in her eyes was pretty awesome. I'd love to replicate something similar.
Now. I figured I could purchase ten or so lights, drill holes in a square piece of wood and wire the lights in a circuit of some sort.
Later on, I'd also like to build a lighting rig out of those long fluorescent tubes. But that rig would be hard to store so I'll need to figure out a way to make it modular or something, photo below is from a music video.
Do you guys have any advice as to what I should do? Maybe a square isn't the best idea, maybe I'll make it rectangular and do a light array of 2-3-2-3-2-3 (over 4-4-4-4).
As for parts, I can buy the bulbs at work, but I can't buy the parts the bulbs would screw into, the wires or much of anything else. How many (different) wires would I need to connect two lights? Sixteen? And but different I'm inquiring something other than wires for positive and negative. Will I need a third wire to connect every other light?
As far as circuitry goes, nothing fancy since I won't be using this for video. Don't need it to flash or scroll light. Just a button for on and off, and *maybe* a dim option. So that if I build more than one I can control the light and set one as the primary and the other as a fill light.
How much more complicated does it get to add a switch and a dimmer? If The dimmer is also the switch, I'd assume it'd be the same rigging as if I just had a on-off switch. So that's what I'd likely do anyways.
When I get around to building this, I'll keep you guys updated if you'd like! But I need to know what sort of parts I'll need to purchase and how many wires and what length. My dad has a soldering gun so that's no issue for me to acquire.
Maybe, if this puts out a cool amount of light. I'll also use it as the main light in my room! Then, just unplug and unmount from the wall when I need to use it else where! Hehe
