Ok, to sum it up. Remember to have extensions enabled, and that all .8x* extensions are usually the file you wanna send to your TI-84+ or TI-83+
Correct, thanks for the accurate summary, Qazz. And when in doubt, or if you have extensions disabled, look for something called DoorsCS7 with an icon that's a yellow lightning bolt over a TI-84+ over a TI-92. qazz42 wrote:
Unless you installed TILP
then it is different
An excellent point, although if you're having trouble identifying an App then I suspect you didn't have the experience or skills to install TiLP. then it is different
qazz42 wrote:
0x5, exactly..
good to know that he got it installed
Definitely. I can only assume that other people will have the same problems in the future, so I'll try to update the readme to handle the case of people without extensions when I release 7.1 with CALCnet2.2 support, but we also know how to answer people with these questions. good to know that he got it installed
» Goto page Previous 1, 2, 3
Page 3 of 3
