This is a thread for people who have questions about Axe Parser. For those of you who don't know what Axe is, Axe is a compiled programming language for the TI-83+/84+/SE line of graphing calculators. Axe is harder than TI-BASIC but easier than Assembly, so it is understandable to have questions and No question is irrelevant so fell free to ask anything about Axe. Please post any questions in the topic below!
I've got a question. How do you get TI-OS Str1 and store its contents to an axe variable in string form?
IIRC, the syntax to get the OS Str1 is:
GetCalc("Str1")→S
However, that's a string of tokens, not characters. Next, you need to iterate over the string to convert the tokens to the relevant ASCII characters you need (in the same way that you do so after an input command). This table of TI-83+ tokens may be helpful. Depending on your requirements, e.g. if you only want A-Z and 0-9, this may be easy. If you want the token for sine to be converted to the string "sin(" then it will likely be more difficult.
Not to be mean or to bring rivalties between websites, but Axe was born on Omnimaga, and therefore a lot of Axe coders are on Omnimaga. This is why it would be better to ask Axe questions on Omnimaga (and this is why a "Axe Q&A" topic already exists on Omnimaga but not on Cemetech).
On the contrary, if I had a question about DoorsCS, I would ask it here, because it was born here.
The Asm code runs a program from Str1.
Str1 = "MOUSE"
GetCalc("Str1")→F
"prgm"+F
Asm(E7FDCB08CEEF9B4AFDCB088E)
It should run the program "MOUSE", but it doesnt!
This is the code I have in my program. It just throws an "Undefined" error when I run the program. What do I do from here?
.XYZMOUSE
If Ans=0
.this is where I get Str1
If GetCalc("Str1")
GetCalc("Str1")->F
1->E
[80C0E0F0F8FCC080]->D
31->Y
47->X
0->A
1->C
Pt-Change(X,Y,D)
While A!=54
If E
copy(F,L1+1,8)
"prgm"->{L1}
0->{{F-2}^^r+L1+1}
L1
...this is the subroutine that runs the program
it is located in an other program...
RPROG()
0->A
0->B
DispGraph
While A=0
getKey->A
B+1->B
If B<500
If C<5
C+1->C
Else
1->C
Pt-Change(X,Y,D)
If A=2
X-C->X
If A=4
Y-C->Y
If A=3
X+C->X
If A=1
Y+C->Y
Pt-Change(X,Y,D)
Pt-Change(X,Y,D)
If Ans=1
X->Ans
If Ans=2
Y->Ans
