Today, i was browsing the forum on my iPhone to find this in the place where SAX normally is
This has never happened before, and the Say button doesn't work.
Looks like a fault on PHP's end. Those numbers relate to the time and I'm also guessing ASCII codes for the opening and closing parenthesis, but the numbers immediately surrounding the letter 'C' are too far apart and are different line to line for me to be sure.
It's likely related to the iPhone by that the JS or some-other engine isn't working the same as a full browser, which would be extremely odd in any case.
Happens to me every so often, though, not recently
(this is on my computer BTW)
Problem solved!
There was this app that I use that set the Safari option of 'Enable JavaScript' to Off. I turned it back on, and now it works!
Neutral
No, no. That's definitely JavaScript. The posts are parsed via JavaScript, so the problem is JavaScript. Make sure JavaScript is enabled and that should solve the problem.
EDIT
Haha, should probably refresh the page before I post next time XD
Glad to see it's been fixed!
JS, PHP. Both languges I don't know and sometimes get them mixed up, even though I know their differences D:
Glad to hear it's fixed!
JS = clientside, PHP = serverside. For the sake of my server I deliver that packed code to save processing and bandwidth, then let the client's browser do the heavy lifting to unpack it. Smile
