Hey, I think what he did isn't half bad, considering his age. Sure it helped the environment a total of NONE, but it's a step in the right direction! Good job, but shouldn't your calc have the battery AND the solar panel so it will work anywhere?
Indeed. Opening up a calculator, prying around inside, and putting it back together in an altered (but functioning state) shows the right sort of curiosity, and should be encouraged, with explanations.
yeah i think i get the general idea that i really did not do such a big environment thing and i understand the explanations thing
this is why i did this to my CRAPPY calculator cause if i screw something up aat least i would not have wasted money
I'll be honest, I've tried this same thing in the past. Then I was working in a room that was just barely not bright enough for the calculator to turn on. I realized the problem.
yah i know what you are talking about i have to levae my calc in pure sunlight OR i have to put it right up to my regular light and that will power it up
meh i guess the calc is not so good at running on solar power
p.s. my self estemm has gone through the roof now that i felt i have accomplished something
edit: in case you are wondering why my typing is bad it is because that
1. i have bad eyesight
2. i am not supposed to be here so i am typing fast
3. the computer screen and its brightness does not really help either
