Sonlen wrote:
You flatter me, sir.
If Sonlen finds himself unable to work on these, I'll try to continue to crank a few out every once in a while.
You wouldn't even want to see how butchered my Professor Oak came out. >.< Those are pretty awesome I'm sure you still did a decent job. If creating them from scratch isn't your area of expertise, have you tried resizing them to 32x32 and then doing pixel replacement/touchup?
That is what I did, and let's just say it wasn't pretty.
On the note of from scratch, I could learn DCS GUI Libs faster then I could get one of those looking good, if you know what I mean.
Awww, and you're doing so well at the the DCSB Libs.
Anywho, let's not hijack Dan's topic; I'll post the next set of sprites when I create them.
So I refuse to let this topic get "outdated" more then a couple days, as this is going to be amazing as soon as we get those sprites moving.
So here is what I have to say about those 32x32 sprites....
GOGOGOGOGOGOGO YOU CAN DO IT!!!! WOOOO
That is all.
That is all.
[ ] Distributed Systems homework questions - due 10/7
[ ] Piccolo precaching addition - due 10/8
[ ] Algorithms dynamic programming review - due 10/11
[ ] Algorithms HW #5 - ~20 subquestions - due 10/13
[ ] CALCnet / DCS stuff - due soon, but lower priority
That is all.
[ ] Cemetech template upgrade
[X] Distributed Systems homework questions - due 10/7[ ] Piccolo precaching addition - due 10/8
[ ] CALCnet / DCS stuff - due soon, but lower priority[/quote]
[X] Cemetech template upgrade
I have an idea, if you can get the outlines made, I can get the details.
But that is up to you.
I'm going to head to lunch now, so maybe I'll do another two while I eat. If so, I'll edit this post with them.
I wouldn't worry yourself too much Kerm, you have a busy schedule for the next few days. I will see about using what is there to at least properly set things up.
This begs the question though, should I go through and just remove the 16x16 sprites used for dialogs or just leave them and just use these for the battle screen?
It would probably make things look nicer if I did the larger instead of the smaller for the dialogs, however I would have to go back through a lot of code to repair all that. Decisions, decisions..
I feel like you should probably put that off for now, tifreak8x, and you can always go back and make that change later.
In all honesty, if you have a 16x16 sprite for each of those npc's, I think that is a good idea, especially considering the size of the screen I think that will look better.
But that is my opinion, and not my game, so in the end, you choice is what counts.
Also, if you don't have all the overworld sprites, but want to use those instead, I could have those in black and white in a couple hours max, so let me know if you need/want those.
This is what I want to see. that is amazing, though I wonder how much you changed since.
oh, a ton since that.
Those are NPCs moving around the screen by the way. I really need to update the listing on the screenshot page for my projects section. someday.
If you sent me what you have, and tell me how to disable the battles, I can start working on maps for you, in fact I insist if that is posible.
It simply would be too much work in the wrong direction for me to do that. I spent a lot of time getting the events system locked in there, which it still needs upgrading. Maps were going to be built on a play as I go basis.
Awww, well as soon as the battle system is set up, I want to start at the end of the game and work my way back, if there is a way I can "modify" my party.
Huzzah and rejoice, we have progress from the great Daniel! Congrats.
lol, that's old stuff Kerm xD
That was to show him more had been done since that screenshot. I am merely working on spriting and the like.
tifreak8x wrote:
0x5, that's old stuff Kerm xD
Well if spriting just "merely" to you, then I think you need a new attitude. :p
Pah, don't downplay your work, it's impressive that you're doing anything on it with all the stuff going on in your life.
This sounds awesome! I can't wait until it's done!!!
And I agree with Kerm, It is awesome!
Keep up the awesome work
