If it comes across a pixel that is already on, it cannot spawn into that spot. And the memory need only contain the pixels spawned in the current and previous loops.
It doesn't test if a pixel is on and then grow that pixel, the "living" pixels are recorded in a list.
Running the program itself would be a horrible implementation, as you'd very quickly be consuming massive amounts of memory. A looped implementation would be far superior.
- Kllrnohj
- ☢ PH34R |\/|3 (Posts: 8196)
- 28 Nov 2009 11:57:29 pm
- Last edited by Kllrnohj on 28 Nov 2009 11:58:46 pm; edited 1 time in total
Doesn't matter, as he has no way to store this information in TI-BASIC. You can't perform operations on something you can't store, and that is your problem right now.
Trying to figure out how to do a fill before you even have the base system implemented is pointless. Figure out how the user can draw on a per-pixel basis and THEN come back and figure out advanced stuff.
While we're on the topic of flood fill or bucket fill algorithms, btw, there's of course the Wikipedia page on the subject:
http://en.wikipedia.org/wiki/Flood_fill
Edit: The queue implementation is obviously the one that you want, since TI-BASIC is a language where the level of recursion required for the recursive implementation is prohibitive for any decent size.
Except TI-BASIC doesn't really have an efficient queue either. Using a list is going to be horribly slow...
I said it before I'll say it again, this really needs to be in assembly to get anything resembling speed out of it.
I've already built a splash fill program in TI-BASIC, and it it's slow, but not mindbendingly slow. I just seem to have misplaced it.
source code for splash fill program
etc. etc. etc for up, down, and right
{S->lPX
{T->lPY
{S->lCX
(T->lCY
1->B
0->C
1->E
repeat B=C
B->C
for(A,E,dim(lPX
If not(pxl-test(lPY(A),lPX(A)-1
then
lPX(A)-1->lCX(dim(lCX)+1
lPY(A)->lCY(dim(lCY)+1
end
for(D,B,dim(lCX))
Pxl-On(lCY(D),lCX(D)
end
dim(lCX->B
end
dim(lPX->E
lCX->lPX
lCY->lPY
end
- Will_W
- Expert (Posts: 529)
- 29 Nov 2009 11:49:30 am
- Last edited by Will_W on 29 Nov 2009 02:46:49 pm; edited 1 time in total
PROGRAM:FILL
:Ans->L3
:L3(3->U
:{L3(1)+L3(3)i->L3
:imag(L3->L6
:real(L3->L3
:L3->LC
:L6->LD
:1->J
:While J
:Delvar Q{0->L4
:{0->L2
:dim(L3->F
:For(A,1,F)
:L3(A->B
:L6(A->C
:C-1->V
:C+1->W
:B-1->G
:B+1->H
:not({pxl-Test(G,V),pxl-Test(G,C),pxl-Test(G,W),pxl-Test(B,V),pxl-Test(B,W),pxl-Test(H,V),pxl-Test(H,C),pxl-Test(H,W->L5
:Ans and {(L5(4) or L5(2)),1,(L5(2) or L5(5)),1,1,(L5(4) or L5(7)),1,(L5(7) or L5(5->L5
:L5{V,C,W,V,C+1,V,C,W->LB
:L5{G,G,G,B,B,H,H,H->LA
:Delvar NDelvar Dsum(L5->M
:While D<M
:N+1->N
:If LA(N
:Then
:LA(N->K
:LB(N->L
:Pxl-On(K,L
:Q+1->Q
:K->L4(Q
:L->L2(Q
:D+1->D
:End
:End
:End
:If not(sum(L4
:Then
:Delvar JEnd
:L4->L3
:L2->L6
:If U
:Then
:{U:prgmFILLTYPE
:End:End
PROGRAM:FILLTYPE
:If Ans(1)=1
:Then
:For(T,1,dim(LC))
:If 2=gcd(2,LC(T)+LD(T
:Then
:Pxl-Off(LC(T),LD(T
:End
:End
:L3->LC
:L6->LD
:End
PROGRAM:FILLTOOL
:a+bi
:25->O
:25->P
:Pxl-Change(O,P
:While 1
:Delvar Z
:While not(Z
:getKey->Z
:End
:Pxl-Change(O,P
:O+(Z=34)-(Z=25->O
:P+(Z=26)-(Z=24->P
:Pxl-Change(O,P
:If Z=21
:Then
:{O,P,0:prgmFILL /////replace the 0 with a 1 for checker fill
:Pxl-Change(O,P
:End
:End
Slightly optimized and bug fixed.
Here's an improvement to your FILLTOOL program:
PROGRAM:FILLTOOL
:a+bi
:0->Xmin:0->Ymin
:1->dX:1->dY
:While 1
:Input
:{X,63-Y,0:prgmFILL /////replace the 0 with a 1 for checker fill
:Pxl-Change(X,63-Y
:End
I had a fill program that filled in horizontal lines instead of pixel to pixel.
It was not perfect because it forget some parts but could be modified... In TI-BASIC this method could be faster...
What should I use input for? Where to start filling? This is supposed to be for a paint program, and most people don't know the exact codes for positions.
For what it's worth, you can transfer Pic variables to and from BBC BASIC by saving and loading the graph buffer memory (&9340) directly. To load and display a picture, use
To save a picture, use
As always, be careful when accessing memory directly!
*LOAD PIC1.PIC 9340
*REFRESH
*SAVE PIC1.PIC 9340+2F4
Page 2 of 3
