Im not to sure where to put this for one thing but I have a few Ideas I think some of you people may find to be very useful (If Possible).
(THESE MAINLY HAVE TO DO WITH TI-BASIC PROGRAMMING LANGUAGE AND NOT ASM OR ANYTHING ELSE UNLESS SPECIFIED!)
1. Option, Hook, Hack, Whatever Ya Call It, That Allows An Archrived File To Run Another Archrived File And Be Able To Return To A The Archrived File If Need Be, Instead Of It Going Back To The DoorsCS Application With An Error Displayed
2. Serious Bug With DoorsCS. If A Program Uses The Function To Run Another Program Thats Archrived An Error Comes Up And If You Press Goto Error, The Calculator Freezes Causing A RAM CLEAR.
3. When Programming And You Press "On" To Cause The Break Error To Use The Goto Error, Make It So You Can Turn On And Off The Scrolling So You Dont Have Wait For The Calculator To Finish Scrolling Through The Codes To Get To The Error.
4. Make It So You Can Set Up Accounts, Like With Login Names And Passwords, So If You Have The Run DoorsCS on Boot up On, It Goes To A Screen And Waits For A Name And Password To Be Entered Before Anything Can Be Done, Mainly To Prevent Other People From Grabbing Your Calculator And Erasing All Memory And Such.
5. Make A Lock Program Function Differently Than it Does Now, Like Make It So If Someone's Program You Downloaded Is Locked It Cant Be Unlocked Without A Password Of Some Sort.
6. Make DoorCS Icons Changable, Like Be Able To Change From Large Icons, Small Icons, List, Or Details
7. Make Lists, Matrices, Ect.. Able To Run On Programs Even If They Are Archrived.
well, Thats All i can think of as of now.
