First post!!!!
This forum needs better emoticons...
I'm going to port over the IPB smilies.
and there lots of texts that r white, white= bad
like in the pms, if u click on 1 of the folders it um becomes invisible
Hey, I just started the skin today, you can't ask for much yet 🙂
I can't find the XYZing color controls... â˜šī¸ 😄
come on i dont wanna here ur complaining!! just get it done!!!! Just Joking
do u mean in the actual php? cuz um i kno NUTHIN about that sry
theres a file called subSilver.css, r the XYZing color controls in there?
well atleast i have that file
OK, I found it now, mod in progress...
Edit: Done.
well ill just let u 'work' and i ll go do some 'real' work (spanish project)
is it possible that u could swap the preview and sumbit buttons? theyre opposite from the other site
I'm definitely going to do that. I used to do [typetypetype][tab][space].
At least you can work on yours, I can't figure out how to edit mine, or get an index page to work... â˜šī¸
Edit: I found it! Now I can do something...
Just go into the cPanel, File Manager, www, tifreakware.calcgames.org, forum, templates, subSilver.
I am trying to change the style of the front page right now. Man this is a pain in the a$$... đŸ˜¯
Indeed it is. But it's fun 🙂
Not when you don't know how!!!!!!!!!!!!!! đŸ˜ĸ
If you say so. The HTML (*.tpl) is fairly easy to understand though...
Ok. I have managed to get my index, the main tutorial page, and the links page set up. I need to install the cgi code for the links yet... 😁
You know how to do that, right?
i wouldn't be surprised if he didn't so i'll say it now, make a folder in the main tifreak.calcgames.org called cgi-bin then put the cgi code in there voila
Also, make sure you put the correct
#usr/bin/perl
or
#usr/local/bin/perl
at the beginning.
It's hard to read your name in the user's online box...it's still white.
I am not that bad!!!!!!! đŸĨˇ
Yes, I put it in the cgi-bin folder, and yes I put in both files that it needs to run. I re-link it to tripod, the page works fine.
Page 1 of 2
