I have decided to create an esoteric programming language. It is called radish. The only instructions are the letters in the word radish. I have no idea how I thought of this.
Here is the instruction set
r = reset the value in memory to 0
a = add 1 to the counter
d = decrement the value in memory
i = increment the value in memory
s = multiply the value in memory by the value of the counter, and reset the counter
h = output the RCS (radish character set) character in memory
RCS Characters
0 = newline
-1 to -10 = 1 to 0, as in -1 = 1, -2=2... and -10 = 0
1-26 = A-Z
27-29 = . , ?
30 = π
I am probably going to try writing an interpreter in TI-BASIC on calc.
Here is a program that prints "radish"
aaaaaaiiish
rih
riiiih
raaaiiish
raaaaaaiiisih
raaaaiish
any suggestions
Here you go:
Code: #include <stdio.h>
#include <string.h>
#include <ctype.h>
#define MAX_PROGRAM_SIZE 10000
// RCS character set mapping
char rcs_to_char(int code) {
if (code == 0) return '\n';
if (code >= -1 && code <= -10) return '0' + (10 + code);
if (code >= 1 && code <= 26) return 'A' + (code - 1);
if (code >= 27 && code <= 29) {
switch(code) {
case 27: return '=';
case 28: return ',';
case 29: return '?';
if (code == 30) return ' ';
return '?'; // Unknown character
void interpret_radish(const char* program) {
int memory = 0;
int counter = 0;
for (int i = 0; program[i] != '\0'; i++) {
char instruction = tolower(program[i]);
switch(instruction) {
case 'r':
// Reset the value in memory to 0
memory = 0;
break;
case 'a':
// Add 1 to the counter
counter++;
break;
case 'd':
// Decrement the value in memory
memory--;
break;
case 'i':
// Increment the value in memory
memory++;
break;
case 's':
// Multiply the value in memory by the value of the counter, and reset the counter
memory *= counter;
counter = 0;
break;
case 'h':
// Output the RCS character
putchar(rcs_to_char(memory));
break;
default:
// Ignore non-radish characters
break;
int main(int argc, char* argv[]) {
if (argc < 2) {
printf("Usage: %s <radish_program>\n", argv[0]);
printf("Example: %s \"raaaaaiiish\"\n", argv[0]);
return 1;
// Concatenate all arguments (in case the program has spaces)
char program[MAX_PROGRAM_SIZE] = "";
for (int i = 1; i < argc; i++) {
strcat(program, argv[i]);
if (i < argc - 1) {
strcat(program, " ");
interpret_radish(program);
printf("\n");
return 0;
wow. that was really fast. did you use ai? (also, that was your 4000th post)
was it Claude?
Yes it was, I don't think it's quite right because I just took a screenshot of the post but most of the core logic is there.
I just tested it, and yes, it is completely broken. I think Claude forgot what a pause in a program is.
PROGRAM:RADISH
:ClrHome
:Disp "RADISH INTERPRETER"
:Disp ""
:Input "PROGRAM: ",Str1
:0→M
:0→C
:1→P
:While P≤length(Str1)
:sub(Str1,P,1)→I
:If I="r"
:Then
:0→M
:End
:If I="a"
:Then
:C+1→C
:End
:If I="d"
:Then
:M-1→M
:End
:If I="i"
:Then
:M+1→M
:End
:If I="s"
:Then
:M*C→M
:0→C
:End
:If I="h"
:Then
:If M=0
:Then
:Disp ""
:End
:If M≥-10 and M≤-1
:Then
:Disp sub("1234567890",-M,1)
:End
:If M≥1 and M≤26
:Then
:Disp sub("ABCDEFGHIJKLMNOPQRSTUVWXYZ",M,1)
:End
:If M=27
:Then
:Disp "."
:End
:If M=28
:Then
:Disp ","
:End
:If M=29
:Then
:Disp "?"
:End
:If M=30
:Then
:Disp "π"
:End
:End
:P+1→P
:End
:Disp ""
:Disp "DONE"
More AI code
I'm not going to use AI, so I am currently writing a TI-BASIC interpreter on calc.
I have finished writing the interpreter. Here is the code:
If Str1=" "
Then
Disp "NO PROGRAM IN STR1"
Pause
ClrHome
length(Str1)->L
0->A
0->I
0->C
Lbl MA
C+1->C
If C>L
Stop
sub(Str1,C,1)->Str2
If Str2="R"
Goto R
If Str2="A"
Goto A
If Str2="D"
Goto D
If Str2="I"
Goto I
If Str2="S"
Goto S
If Str2="H"
Then
Goto H
Else
Disp "INVALID CHARACTER","FOUND AT LINE",C,"THE CHARACTER",Str2,"IS INVALID"
Pause
Lbl R
0->I
Goto MA
Return
Lbl A
A+1->A
Goto MA
Return
Lbl D
I-1->I
Goto MA
Return
Lbl I
I+1->I
Goto MA
Return
Lbl S
I*A->I
0->A
Goto MA
Return
Lbl H
If I=0
Disp " "
If I=~10
Disp 0
If I<0 and I>~10
Disp ~I
If I>0 and I<31
Disp sub("ABCDEFGHIJKLMNOPQRSTUVWXYZ.,?pi",I,1)
Goto MA
Return
All in under 500 bytes. 🙂
Edit by Merth: Consolidated double post.
New update! I have submitted the interpreter to the archives, and I am now waiting for approval 🙂
and its approved
It's not currently showing up on my profile, so here is the link for quick access.
https://www.cemetech.net/downloads/files/2782/x3660
This was very eye-opening, because for some reason I didn't realize you didn't need a Then or End for a single-line If statement. Anyway, neat program.
Yeah, I'm a very self-taught coder, so when I need information on a code block (I coded this and most other TI Basic on calc) I just use the CE's built in catalog help.
Some suggestions:
1. Include a test program! People are always too lazy to write their own, aren't they 😉
2. Ok, this one isn't joking: On the ti83+ and ti84+, the DoorsCS shell will end a tibasic program and clear the screen right at its end, even though there is text on the screen to be read. Although changing "If C>L:Stop" to
"If C>L
Then
Pause
Return
End"
fixes it.
3. The check for if Str1 is empty doesn't work. Maybe ask nicely in the chat? (I dunno a fix)
4. Uh, for reasons quite apparent, I suggest adding a newline character, and maybe an input and random function too.
(May be change the name to "Radishez"?)
Your project completion rate is definitely better that mine's though, so that's a bonus. 🙂
I'm currently working on a 1.1 update that includes revamped error detection, a fix to the Str1 emptiness detector, and support for spaces. I would like to add some more features, because I believe it is not turing complete yet and inputting would be nice. My question is, how could I translate a letter into a number. I know how to do it for numbers, but how could I efficiently translate letters A-Z into numbers 1-26.
Use inString(:
Code: inString("ABCDEFGHIJKLMNOPQRSTUVWXYZ",<letter to check>
will translate A to 1 through Z to 26 (and anything else to 0).
So inString returns the position of the letter when found? I did not know that. I thought that instring just returned 1 for positive and 0 for negative.
(Maybe change the name to "Radishez"?)
I already had a newline character (0), but it automatically adds a newline after a character is printed. This will be fixed in update 1.1. Finally, what would the "ez" in Radishez stand for?
RCS Characters
0 = newline
1-26 = A-Z
27-29 = . , ?
30 = π
aaaaaaiiish
rih
riiiih
raaaiiish
raaaaaaiiisih
raaaaiish
any suggestions
can you make a program that can be a program editor like z80 studio
I would like to create something like ez80 studio, but I am not sure how to use appvars, and there is not much documentation on how to use them online. If I could do it using a BASIC library that would be even better, but C would be fine. Can anyone help me?
