I'm not a very experienced in TI-BASIC (~6 days of experience), and I was wondering what the fastest way is to take a list of numbers representing dice (each number represents the number of sides on each die), and return a list; each item on the returned list would be equal to how many times the sum of the rolled dice was the index of that item, taking into account every possible combination of die rolls.
Here's an example:
{4,4,6}
would result in Code:
{0,0,1,3,6,10,13,15,15,13,10,6,3,1}
Out of the 96(4*4*6) possible combinations, 1 added up to 3, 3 added up to 4, 6 added up to 5, etc.
I have a program that works, but it is very slow. if you enter just 2d100, it will take a VERY long time to finish, as it has to go through my recursion loop a little over 10,000 times.
Here is my implementation, which may or may not be faster than yours. L₁ is where the list input is stored, and L₂ is where the output will be. L₃ is used.
ClrList L₂,L₃
sum(L₁→dim(L₂
1→L₃(1
For(I,1,dim(L₁
AnsL₁(I→L₃(I+1
For(I,0,Ans-1
dim(L₁
Ans+Σ(remainder(int(I/L₃(J)),L₁(J)),J,1,Ans
1+L₂(Ans→L₂(Ans
(Σ( can be replaced with sum(seq( and remainder(A,B) can be replaced with BfPart(A/B))
Maybe you could use the fact that the output is always symmetrical to optimize.
That timeframe sounds about right. It would probably be a more efficient use of your time to do it algebraically, and also, why are you making a program that does that? It also could be faster to do a Monte Carlo simulation, where the list updates in real time and the program runs as long as you want.
Yeah, I probably should have posted that here earlier, because it goes into quite a bit of detail about how to do the type of combinatorics that would be useful here.
Unfortunately it's not solving exactly the same question that was asked here - it's a less general version that assumes that all dice have the same number of sides. You might still be able to use it as an optimization that e.g. counts the number of occurrences of each side count, though.
ClrHome
Input "DICE: ",L₁ // input can be {6,4,…} or L₁ if the list is already set up
L₁(1)→dim(L₂)
Fill(1,L₂) // the outcome for the first dice is a list of ones
For(I,2,dim(L₁)) // makes convolution-ish stuff for each dice left
cumSum(L₂)→L₂
L₁(I)→dim(L₃)
Fill(L₂(dim(L₂)),L₃)
augment(L₂,L₃)-augment(0*L₃,L₂)→L₂
seq(L₂(I),I,dim(L₂),1,-1)→L₂ // flips L₂ because the loop returns a fliped solution
Disp L₂
Pause
The only downside is that when entering too many or too large numbers the results get damaged, probably due to some overflow…
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
