I am trying to make a cube timer that activates when I hold any key for 1 second and starts when that key is released. can anyone give me code that does that in ice or ti-basic? thanks
Edit: or in ASM
Edit: also HEX (i am editing too much
Edit: any on-calc language for the CE (I need to stop editing
That can be done, I’ll send a link with a download file tonight, but you will need a jailbreak to run it(very excessive, I know).
Especially on the forums, we definitely prefer that you post your solutions & their explanations here directly; it is very annoying to have a question and find a search engine result with exactly what you want (except the solution is hidden away in some dead download link or DM).
I have made a few things never had the reason to create an account until today
My bad, basically I just created two while loops, one waiting for user input and the other waiting for the button to be pressed again, its the same one I use for long distance runs, and then I added a hundreds of a seconds counter to it, fair warning, it can be inaccurate, but the tenths and the seconds work fairly well.
source code:
Code: CT
0→K
0→T
While 1=1
getKey→K
If K≠0
Goto A
Lbl A
Disp "GO"
0→K
While K=0
getKey→K
Pause 10
T+1→T
T*110/100→T
Disp T/100,".",remainder(T,100),"secs"
Pause
And here's the link: https://drive.google.com/file/d/1av7h4JTSPkTyXIgihZGb5fEwV4CtQnh6/view?usp=sharing
I'll try to do better on my part next time.
Thx I’ll try it
Edit: can you make it more like a Stackmat timer (I.E. the timer starts when I release the button)
Edit: hello?
