I've had this idea for a while now, but finally had the motivation to work on it over the past week or so. I've seen people who make these framed teardown display pieces out of tech (vintage consoles, phones, tablets, etc.) and I thought it would be fun to make my own with a calculator.
The most time consuming step of this was making a backdrop for the frame. In the pictures I've seen of similar projects, the backdrop usually contains some notes about the hardware, a logo, or other stuff like that. I went pretty minimalist (partly because I don't have the capability to design something very detailed that looks nice), but I'm pretty happy with what I came up with (click images for higher resolution):
I used inkscape to design a vector image that could be scaled to the right dimensions, and the final thing was 13x13 inches.
With the backdrop done, I moved on to disassembling the calculator. This was very straightforward and the most difficult part was removing the screen, which is attached by some annoyingly sticky adhesive.
With all the parts separated and ready to go, all I needed to do attach them to the backdrop:
I don't know tons about making physical stuff (writing software is much less financially burdensome if you make mistakes), but I was recommended to use B6000 glue to attach everything together. So far it seems to be holding up very well!
And finally here's a picture of the finished result:
