- abusing the control stack even more (now with non-primitive recursion!)
- 23 Jun 2024 09:42:50 pm
- Last edited by fghsgh on 23 Jun 2024 10:42:33 pm; edited 2 times in total
So, we already know that TI-BASIC's control flow stack can be used to implement subroutines in TI-BASIC by abusing the "memory leak bug" to implement a return stack:
Another weird bug-thing that has been established before is that you can use unnamed For-loop variables to store data on the same control stack (on CSE and higher). Theoretically, this should make it possible to implement proper recursion in TI-BASIC by making use of just the control stack. Theoretically, of course. This would be entirely too impractical and unreasonable to actually try to implement. It could be a thought experiment at best. A hypothetical edge case in the development of static analysis tools, and even then probably not, because who would be insane enough to actually write something like that.
Therefore, behold, the Ackermann function:
To use, set M and N to those respective arguments, call AK using the method described above, and the result is in A. L1 needs to exist and have at least one element (but it is not accessed nor changed, and there are several alternatives available). We only need to store M and a return address on the stack, and it uses two tail calls. Stack depth scales with N, so it is likely to overflow. This means M is better stored in unary. This makes extraction slow, but it is clear we already didn't care about speed here. This has been an exercise in inanity from the very beginning.
Note: I haven't actually been able to test this. I don't have a CSE or a CE, which support the "unnamed For var" feature (yes I'm calling it a feature now). I'm pretty sure it should work though. (EDIT: Zeroko checked, it works)
Just in case that wasn't enough, a version that doesn't use real variables either:
Or, a version that returns a real in Ans, courtesy of Zeroko:
(both of these should be called using {M,N} in Ans)
Isn't this great? Non-primitive recursion using no reals and no lists! How cool is that! TI-BASIC is such a powerful and fully-featured language!
:"calling a subroutine
:For(A,0,1)
:If not(A
:Goto AA
:End
:"definition of subroutine
:Lbl AA
:Disp "AA
:End
:Lbl A2
:1->N
:M-1->M
:Lbl AK
:If not(M
: Goto A1
:If not(N
: Goto A2
:0->B
:1->C
:N-1->N
:For(L1(1),0,M
: B+1->B
: If C
: Goto AK
:End
:A->N
:B-1->M
:Goto AK
:Lbl A1
:0->B
:0->C
:N+1->A
:End
:Lbl 2
:{Ans(1)-1,1
:Lbl 0
:If not(Ans(1
:Goto 1
:If not(Ans(2
:Goto 2
:{Ans(1),Ans(2)-1,0,1
:For(L1(1),0,Ans(1
:{Ans(1),Ans(2),Ans(3)+1,Ans(4
:If Ans(4
:Goto 0
:End
:{Ans(3)-1,Ans(5
:Goto 0
:Lbl 1
:{Ans(1),Ans(2),0,0,1+Ans(2
:End
:Lbl 2
:{Ans(1)-1,1
:Lbl 0
:If not(Ans(1
:Goto 1
:If not(Ans(2
:Goto 2
:{Ans(1),Ans(2)-1,0,0
:For(L1(1),0,Ans(1
:Ans{1,1,1,1}+{0,0,1,0
:If not(Ans(4
:Goto 0
:End
:{Ans(3)-Ans(4)-1,Ans(4
:Goto 0
:Lbl 1
:1+Ans(2
:End
