- INSTR3MT, a 1-bit, non-polyphonic instrument for the TI-84+
- 27 Nov 2023 10:38:55 pm
- Last edited by Beakbonk on 28 Nov 2023 11:47:37 am; edited 2 times in total
INSTR3MT
This code lets you play your TI-84+ like an instrument. It uses 15 buttons for playing music, and the rest of the buttons to determine which key and scale is being used.
Here is the file: http://ceme.tech/DL2410
In the future I hope to add the ability to tune the instrument (because calculators run at different speeds), and let the user define what scale is set by the [x] button.
Special thanks to fghsgh for replying to a question and showing how a single note might be generated. That code was extremely helpful.
Disclaimers: I have not tested this on a TI-83+. Tuning varies between calculators. A 2.5mm to 3.5mm adapter will be needed to use this with standard headphones
