Hi, I'm trying to implement a menu in a project I'm (trying) to contribute to, and so far, I’ve gotten to the point where the menu appears when you press DEL, but when you select any item using the number keys, the program crashes. Here’s the relevant code:
In the file io.asm (below main.c) , I added the function with extern and called it instead of startJIT.return (find it with ctrl+f and search for showPauseMenu). Can anyone help?
This is main.c:
And this is io.asm:
This is main.c:
#include <stdlib.h>
#include <stdint.h>
#include <stdbool.h>
#include <string.h>
#include <tice.h>
#include <graphx.h>
#include <fileioc.h>
#include <keypadc.h>
#include <sys/timers.h>
ROM Format:
header: appvar with max 6 character name
x = hex digit from 0 to F
NAMEPx - PRG ROM
NAMECx - CHR ROM
NAMESV - compressed PRG RAM
NAMESx - savestate (not yet implemented)
struct romheader {
char magic[8]; // "FAMICALC"
uint8_t mapper; // ines mapper
uint8_t mirroring; // 0 = Vertical, 1 = Horizontal, 2+ = other
uint8_t prgsize; // in 16kb units
uint8_t chrsize; // in 8kb units (0 = CHR RAM)
char description[]; // Text to display on select screen (null terminated).
extern struct romheader* header;
extern void* prg_banks[64];
extern void* chr_banks[512];
// startJIT() is the external function that begins the emulation session.
// It should periodically check the global flag `exit_emulation` (set in the pause menu)
// and return when that flag is true.
extern void startJIT(void);
extern void ui_init(void);
extern void ui_cleanup(void);
extern void ui_printString(uint8_t x, uint8_t y, const char* string);
uintptr_t jit_cache_extend;
uintptr_t jit_cache_extend_end;
void* getFileDataPtr(char prefix, uint8_t id, char* romname);
bool loadROM(uint8_t index);
struct romheader* roms[16];
const char version_string[] = " *FamiCalc version 0.1* ";
extern void showPauseMenu(void);
void handlePauseMenuSelection(uint8_t selection);
// Global flag used to signal that the user wants to exit the current emulation session
// and return to the ROM selection menu.
bool exit_emulation = false;
int main(void)
kb_SetMode(MODE_3_CONTINUOUS);
// Main loop: each iteration is one ROM selection and emulation session.
while (1) {
ui_init();
// Find free memory for JIT cache.
jit_cache_extend_end = os_MemChk(&jit_cache_extend);
jit_cache_extend_end = jit_cache_extend_end + jit_cache_extend - 256;
// Display title and instructions.
ui_printString(8, 0, version_string);
ui_printString(8, 16, "Press ENTER to select a ROM");
ui_printString(8, 24, "Press DEL to exit.");
// Gather up to 16 ROMs on the calculator.
int numRoms = 0;
void* vat_ptr = NULL;
char* varname;
uint8_t cury = 40;
memset(roms, 0, sizeof(roms)); // Clear ROM list.
while ((varname = ti_Detect(&vat_ptr, "FAMICALC"))) {
ui_printString(16, cury, varname);
ti_var_t f = ti_Open(varname, "r");
roms[numRoms] = ti_GetDataPtr(f);
ti_Close(f);
numRoms++;
if (numRoms == 16)
break;
cury += 10;
// Let the user choose a ROM.
uint8_t selection = 0;
kb_lkey_t last = 0;
cury = 40;
ui_printString(8, cury, ">");
ui_printString(8, 208, roms[selection]->description);
while (1) {
bool newSelection = false;
if (kb_IsDown(kb_KeyDel)) {
ui_cleanup();
return 0;
} else if (kb_IsDown(kb_KeyEnter))
break;
if (!kb_IsDown(last)) {
last = 0;
if (kb_IsDown(kb_KeyUp)) {
if (selection > 0) {
selection--;
newSelection = true;
last = kb_KeyUp;
} else if (kb_IsDown(kb_KeyDown)) {
if (selection < numRoms - 1) {
selection++;
last = kb_KeyDown;
if (newSelection) {
// Clear previous marker and description.
ui_printString(8, 40, " ");
cury = 40 + selection * 10;
ui_printString(8, 208, " ");
ui_printString(8, 216, " ");
header = roms[selection];
if (loadROM(selection)) {
exit_emulation = false; // Clear the flag before starting.
startJIT(); // Begin the emulation.
// When startJIT() returns, either the game ended naturally or the user selected
// "Main Menu" from the pause menu.
} else {
ui_printString(8, 208, "Error opening ROM!");
ui_cleanup();
continue; // Return to ROM selection.
ui_cleanup();
return 0;
bool loadROM(uint8_t index) {
char romname[16];
char* varname;
for (uint8_t i = 0; i < index + 1; i++)
varname = ti_Detect(&vat_ptr, "FAMICALC");
strcpy(romname, varname);
uint8_t prgsize = header->prgsize;
uint8_t chrsize = header->chrsize;
// Locate PRG data.
for (unsigned int i = 0; i < 2 * prgsize; i++) {
uint8_t id = i / 6;
int offset = 8192 * (i % 6);
void* dataptr = getFileDataPtr('P', id, romname);
if (dataptr)
prg_banks[i] = dataptr + offset;
else
return false;
// Mirror by copying filled section to empty section.
memcpy(&prg_banks[2 * prgsize], &prg_banks[0], (64 - (2 * prgsize)) * sizeof(void*));
if (chrsize == 0) return true;
// Repeat for CHR data.
for (unsigned int i = 0; i < 8 * chrsize; i++) {
uint8_t id = i / (8 * 7);
int offset = 1024 * i;
void* dataptr = getFileDataPtr('C', id, romname);
if (dataptr)
chr_banks[i] = dataptr + offset;
else
return false;
memcpy(&chr_banks[8 * chrsize], &chr_banks[0], (512 - (8 * chrsize)) * sizeof(void*));
return true;
void* getFileDataPtr(char prefix, uint8_t id, char* romname) {
char filename[16];
char ext[3];
ti_var_t f;
void* dataPtr = NULL;
ext[0] = prefix;
ext[1] = id >= 0x0A ? 'A' + (id - 0x0A) : '0' + id;
ext[2] = 0;
// Construct file name.
strcpy(filename, romname);
strcat(filename, ext);
if ((f = ti_Open(filename, "r"))) {
dataPtr = ti_GetDataPtr(f);
ti_Close(f);
return dataPtr;
// This function is expected to be called (from within your JIT/emulation code)
// when the user pauses the game.
void showPauseMenu(void) {
// (Optional) Clear or draw a background for the pause menu.
ui_printString(8, 80, "Pause Menu: ");
ui_printString(8, 96, "1. Resume ");
ui_printString(8, 104, "2. Main Menu ");
ui_printString(8, 112, "3. Quit ");
kb_lkey_t last = 0;
while (1) {
last = 0;
if (kb_IsDown(kb_Key1)) {
selection = 1;
break;
} else if (kb_IsDown(kb_Key2)) {
selection = 2;
break;
} else if (kb_IsDown(kb_Key3)) {
selection = 3;
break;
handlePauseMenuSelection(selection);
// This function performs the action based on the pause menu selection.
void handlePauseMenuSelection(uint8_t selection) {
switch (selection) {
case 1:
// Resume: simply return control so that the emulation resumes.
break;
case 2:
// Main Menu: signal to exit the current emulation session.
exit_emulation = true;
break;
case 3:
// Quit: clean up and exit the application.
ui_cleanup();
exit(0);
break;
default:
break;
And this is io.asm:
include 'ti84pceg.inc'
section .text
public io_init
public io_get_read_function
public io_get_read_function.io_lut
public io_get_read_function.ppu_lut
public io_get_write_function
public io_get_write_function.io_lut
public io_get_write_function.ppu_lut
public io_read_status
public io_read_joy1
public io_read_joy2
public write_dmc_freq
public write_dmc_start
public write_dmc_length
public write_oam_dma
public write_apu_enable
public write_joy_strobe
public write_apu_frame
public read_ppu_io_bus
public read_ppu_status
public read_oam_data
public read_ppu_data
public write_ppu_control
public write_ppu_mask
public write_ppu_io_bus
public write_oam_address
public write_oam_data
public write_ppu_scroll
public write_ppu_address
public write_ppu_data
public ppu_video_start
public ppu_video_end
public io_frame_irq
public set_mirroring
public attribute_update
include 'vars.inc'
;TODO:
io_init:
; blank area
ld ix,jit_scanline_vars
lea hl,ix+0
lea de,ix+1
ld (hl),0
ld bc,127
ldir
ld hl,jit_event_stack_top+2*264 ; set to dummy line thats never reached
ld (frame_counter_irq_line),hl
ld (ppu_address_increment),1
ld hl,render_event_list
ld (ppu_event_list),hl
ld (frameskip),60 ; 1 second of setup
ret
set_mirroring:
bit 0,a
jr nz,.horizontal
.vertical:
ld hl,ppu_nametables
ld (ppu_nametable_ptr),hl
ld (ppu_nametable_ptr+3),hl
ld hl,ppu_nametables+2048
ld (ppu_nametable_ptr+6),hl
ld (ppu_nametable_ptr+9),hl
ret
.horizontal:
ret
ppu_video_start:
res 6,(ppu_status) ; clear sprite zero flag
res 7,(ppu_status) ; clear vblank flag, if not already
res 0,(in_vblank)
inc (current_frame)
.smc_spz_line:= $-3
res scan_event_sprite_zero,(hl)
; handle keys
push af
push bc
ld a,(ti.mpKeyData+2) ; return if DEL down
and a,$80
jp nz,_showPauseMenu
call get_keys
ld (joypad1_input),a
; compute sprite zero line
ld de,ppu_oam
ld a,(de)
cp a,239
jq nc,.skip ; offscreen
inc de
; get pointer to sprite data
ld a,(de)
dec de
; find bank
bit 5,(ppu_ctrl) ; 8x8 or 8x16 ?
jr z,.x8
.x16:
rrca
ld l,a
ld h,8
mlt hl
jr .l1
.x8:
ld h,4
ld l,a
mlt hl
bit 3,(ppu_ctrl) ; sprite data at $0000 or $1000?
jr z,.l1
set 2,h ; +4
.l1:
ld l,3
mlt hl
ld bc,ppu_chr_ptr
add hl,bc
ld hl,(hl)
; add offset
and a,111111b
ld b,16
bit 5,(ppu_ctrl) ; 8x16 means 32 byte sprites
jr z,.l2
and a,11111b
ld b,32
.l2:
ld c,a
ld a,b
mlt bc
add hl,bc
push hl
pop iy
; find first opaque line
srl a
ld b,a
ld c,a
.l3:
ld a,(iy)
inc hl
or a,(iy+8)
jr nz,.l4
inc iy
djnz .l3
.l4:
ld iy,jit_nes_iwram+$80
ld a,b
or a,a ; if a=0 then there is no hit
jr z,.skip
ld a,c
sub a,b
ex de,hl
add a,(hl)
cp a,239 ; offscreen?
jr nc,.skip
inc a ; rendered at +1
ld l,a
ld h,2
mlt hl
ld de,jit_event_stack_top
add hl,de
set scan_event_sprite_zero,(hl)
ld (.smc_spz_line),hl
.skip:
; store initial ppu config
ld a,(ppu_ctrl)
ld (ppu_ctrl_backup),a
ld a,(ppu_mask)
ld (ppu_mask_backup),a
ld a,(ppu_x_scroll)
ld (ppu_x_backup),a
ld a,(ppu_y_scroll)
ld (ppu_y_backup),a
ld hl,ppu_chr_ptr
lea de,chr_ptr_backup_0
ld bc,3*8
ldir
ld hl,ppu_nametable_ptr
lea de,nametable_backup
ld bc,3*4
ldir
;reset event list
; enable rendering if on a render frame
ld a,(frameskip)
cp a,(current_frame)
jr nz,.norender
ld (current_frame),0
ld a,$80
.norender:
ld r,a
pop bc
pop af
ret
ppu_video_end:
set 7,(ppu_status) ; set vblank flag
set 0,(in_vblank)
push af
push bc
push hl
exx
push hl
push bc
ld hl,i
push hl
ld a,r ; is rendering enabled?
rla
jr nc,.norender
; mark end of event list
ld hl,(ppu_event_list)
; reset list if trailed passed the end
ld de,render_event_list_end
or a,a
sbc hl,de
add hl,de
jr c,$+6
ld (hl),240
call render_draw
call load_jit_search ; reset SHA area
.norender:
; clear any pending VCOMP interrupts
ld hl,ti.mpLcdIcr
set 3,(hl)
; disable rendering
xor a,a
ld r,a
pop hl
ld i,hl
pop bc
pop hl
exx
pop hl
pop bc
pop af
bit 7,(ppu_ctrl)
ret
; a = NES key result
get_keys:
ld hl,ti.mpKeyData
ld de,key_list
ld b,8
ld c,0
.loop:
ld a,(de) ; read row
inc de
add a,a
add a,$10
ld l,a
ld a,(de) ; read column
inc de
and a,(hl)
jr z,.off ; shift in bit
.on:
scf
.off:
rl c
djnz .loop
ld a,c
ld de,0
ret
key_list:
db 1,1 shl 5 ; A
db 2,1 shl 7 ; B
db 3,1 shl 7 ; Select
db 1,1 shl 6 ; Start
db 7,1 shl 3 ; Up
db 7,1 shl 0 ; Down
db 7,1 shl 1 ; Left
db 7,1 shl 2 ; Right
io_frame_irq:
set 6,(apu_status)
ret
; hl = address
; returns: hl = function, a = inline(true/false)
io_get_read_function:
ld a,h
cp a,$40
jr c,.ppu
ld a,l
cp a,$15 ; <$4015 all open bus
jr c,.openbus
cp a,$18
jr nc,.openbus
sub a,$15
ld c,a
ld b,3
mlt bc
ld hl,.io_lut
add hl,bc
ld hl,(hl)
xor a,a
ret
.ppu:
ld a,l
and a,111b
cp a,2 ; reading from $2002?
jr z,.inline
ld c,a
ld b,3
mlt bc
ld hl,.ppu_lut
add hl,bc
ld hl,(hl)
xor a,a
ret
.inline:
ld hl,read_ppu_status_inline
ld a,1
ret
.openbus:
ld hl,io_open_bus
xor a,a
ret
.io_lut:
emit 3: io_read_status,io_read_joy1,io_read_joy2
.ppu_lut:
emit 3: read_ppu_io_bus, read_ppu_io_bus, read_ppu_status, read_ppu_io_bus
emit 3: read_oam_data, read_ppu_io_bus, read_ppu_io_bus, read_ppu_data
io_get_write_function:
ld a,h
cp a,$40
jr c,.ppu
ld a,l
cp a,$14 ; <$ignore writes before $4014
jr c,.openbus
cp a,$18 ; and >$4017
jr nc,.openbus
sub a,$14
ld c,a
ld b,3
mlt bc
ld hl,.io_lut
add hl,bc
ld hl,(hl)
xor a,a
ret
.ppu:
ld a,l
and a,111b
ld c,a
ld b,3
mlt bc
ld hl,.ppu_lut
add hl,bc
ld hl,(hl)
xor a,a
ret
.openbus:
ld a,1
ret
.io_lut:
;emit 3: write_dmc_freq , 0, write_dmc_start, write_dmc_length
emit 3: write_oam_dma, write_apu_enable, write_joy_strobe, write_apu_frame
.ppu_lut:
emit 3: write_ppu_control, write_ppu_mask, write_ppu_io_bus, write_oam_address
emit 3: write_oam_data, write_ppu_scroll, write_ppu_address, write_ppu_data
io_open_bus:
ld e,h
ret
io_read_status:
ld e,(apu_status)
res 6,(apu_status) ; reading resets APU frame interrupt
ret
io_read_joy1:
ld l,a
ld a,(joypad1_shift)
scf ; shift 1 into register
rla
ld (joypad1_shift),a
rla
and a,1
or a,$40 ; open bus on top bits
ld e,a
ld a,l
ret
io_read_joy2:
ld l,a
ld a,(joypad2_shift)
rla
ld (joypad2_shift),a
rla
and a,1
ld e,a
ld a,l
ret
; reloads shift registers
write_joy_strobe:
push af
ld a,(joypad1_input)
ld a,(joypad2_input)
pop af
ret
; TODO: DMC irq support
write_dmc_freq:
write_dmc_start:
write_dmc_length:
write_apu_enable:
ret
; if top two bits are both reset, enables irq next frame
write_apu_frame:
; reschedule previous irq
ld hl,(frame_counter_irq_line)
res.sis scan_event_apu_irq,(hl)
; set flag for previous line(on next frame)
bit 7,e ; don't start if in 5-step mode
ret nz
bit 6,e ; don't start if interrupt is inhibited
ret nz
or a,a
sbc hl,hl
add.sis hl,sp
dec hl
dec hl
set.sis scan_event_apu_irq,(hl)
ret
read_ppu_io_bus:
ld e,d
ret
read_ppu_status_inline:
db read_ppu_status.end - read_ppu_status
read_ppu_status:
ld (ppu_write_latch),0
ld e,(ppu_status)
res 7,(ppu_status) ; free to clear bit if past preline
.end:
ret
; copies from specified page to oam
write_oam_dma:
push bc
push de
ld d,3 ; fetch page address
mlt de
ld hl,jit_translation_buffer
add hl,de
ld hl,(hl)
ld de,-128
add hl,de
ld de,ppu_oam
ld bc,256
ldir
pop de
pop bc
; discard next 4 scanlines
; TODO: carry over events that occur in this time frame, also add more granularity (512 cycles exactly)
pop.sis hl
pop.sis hl
pop.sis hl
pop.sis hl
ex af,af'
sub a,512 - 114*4
jr nc,$+3
xor a,a
ex af,af'
ret
read_oam_data:
ld hl,ppu_oam
ld l,(oam_address)
ld e,a
ld a,(oam_address)
and a,11100011b ; mask out unimplemented bits
ld l,a
ld a,e
ld e,l
ret
write_oam_address:
ld (oam_address),e
ret
write_oam_data:
ld hl,ppu_oam
ld l,(oam_address)
ld (hl),e
inc (oam_address)
ret
write_ppu_control:
ld (ppu_ctrl),e
ld l,1
bit 2,e ; get address increment amount
jr z,$+4
ld l,32
ld (ppu_address_increment),l
.skip:
ld l,a
ld a,r
ld a,l
ret p
.active_render:
pop.sis de
push.sis de
ld (hl),d
inc hl
ld (hl),ppu_event_ctrl
inc hl
ld e,(ppu_ctrl)
ld (hl),e
inc hl
ld d,0
ret
write_ppu_mask:
ld (ppu_mask),e
ld e,a
ld a,r
ld a,e
ret p
pop.sis de
push.sis de
ld (hl),d
inc hl
ld (hl),ppu_event_mask
inc hl
ld e,(ppu_mask)
ld (hl),e
inc hl
ld d,0
ret
write_ppu_io_bus:
ret
write_ppu_scroll:
bit 0,(ppu_write_latch)
jq nz,yscroll
xscroll:
ld (ppu_write_latch),1
ld l,a
ld (ppu_x_scroll),e
ld a,r
ld a,l
ret p
.x_scroll_event:
pop.sis de
push.sis de
ld (hl),d
inc hl
ld (hl),ppu_event_scroll_x
inc hl
ld e,(ppu_x_scroll)
ld (hl),e
inc hl
ld d,0
ret
yscroll:
; writes to y scroll don't effect rendering unless T is flushed
ld (ppu_y_scroll),e
ld d,0
ret
write_ppu_address:
jq nz,.write2
.write1:
ld (ppu_address_new_high),e
; writes to address effect scroll
ld l,a
; nametable select
ld a,(ppu_ctrl)
and a,11111100b
ld h,a
ld a,e
rra
rra
and a,11b
or a,h
ld (ppu_ctrl),a
; y fine and top 2 of y course
ld a,e
rla
rla
rla
rla
and a,011b ; topmost fine bit is cleared
ld h,a
ld a,(ppu_y_scroll)
and a,00111000b
or a,h
ld h,a
ld a,e
rra
rra
rra
and a,11000000b
or a,h
ld (ppu_y_scroll),a
ld a,l
ret
.write2:
ld l,a
ld (ppu_address),e
ld a,(ppu_address_new_high)
and a,$3F ; mask out top bits
ld (ppu_address+1),a
; x course
ld a,(ppu_x_scroll)
and a,111b
ld h,a
ld a,e
rla
rla
rla
and a,11111000b
or a,h
ld (ppu_x_scroll),a
; low 3 bits of y course
ld a,(ppu_y_scroll)
and a,11000111b
ld h,a
ld a,e
rra
rra
and a,00111000b
or a,h
ld (ppu_y_scroll),a
; during render?
ld a,r
ld a,l
ret p
pop.sis de
push.sis de
ld (hl),d
inc hl
ld (hl),ppu_event_address
inc hl
; write new x,y,and nametable select
ld e,(ppu_ctrl)
ld (hl),e
inc hl
ld e,(ppu_y_scroll)
ld (hl),e
inc hl
ld e,(ppu_x_scroll)
ld (hl),e
inc hl
ld d,0
ret
; TODO: this could be faster
read_ppu_data:
push af
ld a,r
rla
jr c,.ppu_read_during_render
.get_byte:
ld hl,ppu_read_lut
ld a,(ppu_address+1)
and a,$3F
ld l,a
ld l,(hl)
jp (hl)
; reading from PPUDATA during rendering causes increment to Y scroll and X course scroll
.ppu_read_during_render:
pop.sis de
push.sis de
ld (hl),d
inc hl
ld (hl),ppu_event_read
inc hl
ld d,0
jr .get_byte
write_ppu_data:
push af
ld hl,ppu_write_lut
and a,$3F
ld l,a
ld l,(hl)
jp (hl)
; align to page boundary
rb $100 - ($ and $FF)
ppu_read_lut:
db 4 dup (read_chr_0 and $FF)
db 4 dup (read_chr_1 and $FF)
db 4 dup (read_chr_2 and $FF)
db 4 dup (read_chr_3 and $FF)
db 4 dup (read_chr_4 and $FF)
db 4 dup (read_chr_5 and $FF)
db 4 dup (read_chr_6 and $FF)
db 4 dup (read_chr_7 and $FF)
db 4 dup (read_nametable_0 and $FF)
db 4 dup (read_nametable_1 and $FF)
db 4 dup (read_nametable_2 and $FF)
db 4 dup (read_nametable_3 and $FF)
db 3 dup (read_nametable_3 and $FF)
db read_palette and $FF
read_palette:
ld hl,ppu_palettes
ld de,(ppu_address)
ld a,e
and a,11111b ; mirroring
tst a,0011b ; set to zero if multiple of 4
jr nz,.skip
xor a,a
.skip:
ld l,a
jr read_generic.skip
; need 4 since the mirroring is variable
read_nametable_0:
ld hl,(ppu_nametable_ptr)
jr read_nametable_generic
read_nametable_1:
ld hl,(ppu_nametable_ptr+3)
read_nametable_2:
ld hl,(ppu_nametable_ptr+3*2)
read_nametable_3:
ld hl,(ppu_nametable_ptr+3*3)
read_nametable_generic:
ld de,(ppu_address)
ld a,d
and a,11b
ld d,a
add hl,de
add hl,de
ld d,(ppu_address+1)
read_chr_0:
ld hl,(ppu_chr_ptr)
jr read_generic
read_chr_1:
ld hl,(ppu_chr_ptr+3)
jr read_generic
read_chr_2:
ld hl,(ppu_chr_ptr+3*2)
jr read_generic
read_chr_3:
ld hl,(ppu_chr_ptr+3*3)
jr read_generic
read_chr_4:
ld hl,(ppu_chr_ptr+3*4)
jr read_generic
read_chr_5:
ld hl,(ppu_chr_ptr+3*5)
jr read_generic
read_chr_6:
ld hl,(ppu_chr_ptr+3*6)
jr read_generic
read_chr_7:
ld hl,(ppu_chr_ptr+3*7)
read_generic:
ld de,(ppu_address)
ld a,d
and a,11b
ld d,a
add hl,de
.skip:
ld a,(hl)
or a,a
sbc hl,hl
ld l,(ppu_address_increment)
ex de,hl
add hl,de
ld (ppu_address),hl
ld e,(ppu_read_buffer)
ld (ppu_read_buffer),a
pop af
ret
assert $ - ppu_read_lut <= 256
ppu_write_lut:
db 32 dup (write_chr and $FF)
db 4 dup (write_nametable_0 and $FF)
db 4 dup (write_nametable_1 and $FF)
db 4 dup (write_nametable_2 and $FF)
db 4 dup (write_nametable_3 and $FF)
db 3 dup (write_nametable_3 and $FF)
db write_palette and $FF
write_palette:
ld hl,ppu_palettes
ld a,(ppu_address)
cp a,$10 ; set to zero if = $10
jr nz,.skip
xor a,a
.skip:
ld l,a
ld a,e
ld de,(ppu_address)
jr write_generic.skip2
write_nametable_0:
jr write_nametable_generic
write_nametable_1:
write_nametable_2:
write_nametable_3:
write_nametable_generic:
push hl
ld hl,(ppu_address)
ld a,h
and a,11b ; mask out high bits to get offset
ld h,a
add hl,hl
ld a,e
pop de
add hl,de
inc l
res 7,(hl) ; mark as being written to.
dec l
ld de,(ppu_address)
write_chr:
ld a,e
ld hl,(ppu_address) ; find update flag
repeat 4 ; >> 4
srl h
rr l
end repeat
ld de,render_chrram_flags
add hl,de
ld (hl),1
ld hl,ppu_chr_ram
write_generic:
ld a,e
.skip:
ld de,(ppu_address)
add hl,de
.skip2:
ld (hl),a
or a,a
sbc hl,hl
ex de,hl
add hl,de
ld (ppu_address),hl
ld e,a
pop af
ret
assert $ - ppu_write_lut <= 256
; hl = address
attribute_update:
ld iy,ppu_nametables + 1
ld hl,ppu_nametables + 960*2 + 1
call update_nametable
ld iy,ppu_nametables + 2048 + 1
ld hl,ppu_nametables + 2048 + 960*2 + 1
ld iy,ppu_nametables + 2048*2 + 1
ld hl,ppu_nametables + 2048*2 + 960*2 + 1
ld iy,ppu_nametables + 2048*3 + 1
ld hl,ppu_nametables + 2048*3 + 960*2 + 1
ret
update_nametable:
exx
ld c,11b
exx
ld c,7
.start:
ld b,8
.loop:
bit 7,(hl) ; if bit 7 is 0, tile needs updating
jr z,.update
.return:
set 7,(hl)
inc hl
inc hl
lea iy,iy+8
djnz .loop
inc iyh
ld iyl,1
dec c
jr nz,.start
ld b,8
.l2: ; avoid corrupting attributes
bit 7,(hl)
jq z,.update2
.return2:
set 7,(hl)
inc hl
inc hl
lea iy,iy+8
djnz .l2
ret
.update:
dec hl
ld a,(hl)
inc hl
exx
ld b,a ; fetch pattern
and a,c ; mask out top six bits
rr b
rr b
ld (iy+0),a
ld (iy+2),a
ld (iy+64),a
ld (iy+64+2),a
ld a,b
and a,c
rr b
rr b
ld (iy+4),a
ld (iy+6),a
ld (iy+64+4),a
ld (iy+64+6),a
lea iy,iy+127
inc iy
ld a,b
and a,c
rr b
rr b
ld (iy+0),a
ld (iy+2),a
ld (iy+64),a
ld (iy+64+2),a
ld a,b
and a,c
ld (iy+4),a
ld (iy+6),a
ld (iy+64+4),a
ld (iy+64+6),a
lea iy,iy-128
exx
jq .return
.update2:
dec hl
ld a,(hl)
inc hl
exx
rr b
rr b
ld (iy+0),a
ld (iy+2),a
ld (iy+64),a
ld (iy+64+2),a
ld a,b
and a,c
rr b
rr b
ld (iy+4),a
ld (iy+6),a
ld (iy+64+4),a
ld (iy+64+6),a
exx
jq .return2
section .bss
public ppu_nametable_ptr
public ppu_chr_ptr
ppu_nametable_ptr: rb 3*4 ; ptr's to current vram configuration.
ppu_chr_ptr: rb 3*8
extern jit_translation_buffer
extern load_jit_search
extern _startJIT
extern _startJIT.return
extern _showPauseMenu
extern render_draw
extern scanline_cycle_count
