Hi there,
I'm trying to write a demoscene effect and therefore I need about $1800 bytes of free ram for tables, from what I read free RAM is very limited, is there a way to have fixed area of 6 kb of RAM free for my program?
Easily. Assuming your program leaves 6KB of usermem free, you can use insertmem to reserve a block of memory, then delmem when you're done with it. Just be sure not to create or delete any variables while that memory is reserved.
thanks for the hint, I tried to create AppVar and expand it to $1900 bytes
reserve_memory:
 ld hl,AmountOfRAMINeed; where AmountOfRAMINeed is a the number of bytes you need
 bcall(_enoughmem)
 ret c
 ld hl,AppVarName
 rst rMOV9TOOP1
 bcall(_CreateAppVar)
insert_memory:
 ld hl,reserve ; number bytes to insert
 b_call(_enoughmem) ; check for free ram
 ret c ; ret ca = 1 if not
 ld hl,AppVarName
 b_call(_mov9toop1) ; op1 = name of appvar
 b_call(_chkfindsym) ; de = pointer to data if exists
 inc de
 inc de
 ld (variable_data_start),de
 dec de
 dec de
 ret c ; ret if not found
 ld a,b ; archived status
 add a,0ffh ; if archived then ca = 1
 ret c ; ret if archived
 push de ; save pointer to size bytes of
; data
 inc de
 inc de ; move de past size bytes
 b_call(_insertmem) ; insert the memory
 pop hl ; hl = pointer to size bytes
 push hl ; save
 b_call(_ldhlind) ; hl = old size of appvar,
; number bytes
 ld bc,reserve
 add hl,bc ; increase by 10, amount inserted
 ex de,hl ; de = new size
 pop hl ; pointer to size bytes location
 ld (hl),e
 inc hl
 ld (hl),d ; write new size.
 or a ; ca = 0 each or resets C
 ret
reserve .equ $1980
AmountOfRAMINeed .equ 10
AppVarName:
.db AppVarObj,"AVDATA",0
variable_data_start .dw $ffff
but when I try to use "variable_data_start" as a pointer to free memory I get garbage on screen, I tested the very same code on ZX Spectrum and it works with no problems whatsoever. I make sure that the intervals between writes to lcd are long enough. What could be the reason for the bad data in the window I reserved?
oh, it turned out that I needed to disable interrupts each time I entered the loop, wasn't aware of that Smile
Interrupts shouldn't affect anything in your AppVar, but if you're using the shadow registers, the iy register, or a few other things, you should avoid interrupts (and probably also BCALLs).
