In order to fulfill my American obligation to strap a gun to everything, I've created a calculator flamethrower I call the Portable Intelligence Incinerator. Or as Zeroko puts it, a weapon of 'math instruction'.
In actuality, ever since I saw the Boring Not-A-Flamethrower in 2018 I had a serious desire to create my very own. Fast forward 7 years, I have a Maker space full of tools and the know-how to put one together!
Based on a video from the Hacksmith I learned I could make this project relatively safe by using off the shelf parts already designed to handle flammable gasses. I still don't recommend inexperienced engineers go out and cobble one together. Propane can be extremely dangerous and explosive if you don't follow all precautions.
To pull back the curtain a bit, all I started with was just an old Nerf gun (n-strike alpha trooper) and a weed burning torch from Harbor Freight for $26. I began by gutting the nerf gun, then straightening the bent neck of the torch so it'd properly fit in the shell. I also bent the handle so it'd line up with the existing trigger area.
After much cutting the inside plastic of the Nerf gun (careful to avoid screw holes), and a bit of shaving to the plastic handle, I had a functional prototype done in just one day!
The other features I wanted to add were: making it completely hand-held (currently it had a hose to a 20lbs tank), add a cool paint job, a built-in igniter, a calculator, and a wall mount.
The igniter was difficult to install in a way I didn't expect. Shaving it down to fit inside the handle of the gun was the easy part. The hard part was keeping it from arcing through the wire! I don't know what voltage this igniter is capable of but it can make over an inch long spark in air, and will also arc through its own its own insulation! Multiple layers of heat shrink and kapton tape aren't enough to prevent internal arcing so I had to route the igniter cable outside the gun as you'll see in later pictures.
The paint job was only tricky because I've never painted a detailed model before. Sanding took hours and was pretty miserable to get all the nooks and crannies. I knew that the glossy Nerf gun wouldn't hold on to paint well so I needed to get it as sanded as possible. After applying primer, I spent another few hours masking off the parts that I wanted to be white. I hit the gun with some high gloss black spray paint and it turned out pretty good!
Once I inverted my mask and applied the white paint it was really coming together! At first glance it looked good but then I realized I made a huge blunder. I used paper towels to cover up large areas of the gun. These were apparently not lint free and got tiny hairs stuck all over the paint. Sad
There was no way in hell I was going to sand all the paint off and redo days of tedious work so I went to Walmart and picked up some acrylic black hobby paint. This surprisingly color matched decently well so I also used it to apply a few detailing bits. Lastly, I decided to paint the trim pieces red and I applied some clear coat to protect the paint from becoming even worse. Laughing
With all the cosmetic parts done, I just needed to finalize how to connect the 1lbs propane tank to the torch. I wanted the connection to be hard-line since I didn't want to make my own hose. Finding the right adapter was impossible. Partly because the torch's documentation falsely said the connection was 5/8" (it's actually 3/8") and partly because I needed a very odd configuration. I need the propane tank level-ish with the ground at all times. If it tips too far then liquid propane will get into the torch and cause a bad time. I ended up with a very messy adapter set up (since I originally thought I was adapting from 5/8").
  • Torch 3/8" male
  • 3/8" female swivel coupler
  • 3/8" male to 1/2" female
  • 1/2" male elbow ball valve to female 1/2"
  • 1/2" male to 1/4" female
  • 1/4" female to 1lbs propane bottle
I wanted to hang this on my wall when I'm not using it so I spent about half a day making a wall mount. I also discovered the magazine receptacle is the perfect width to fit a TI-84 Plus CE. I'm thinking of getting a Vernier temperature probe and measuring the heat of the flame. What do you think I should do with it?
With all that here's my most recent test of burning a piece of cardboard (very impressive, I know Razz ).
It's been a great learning project I'm glad I could do for just around $100.
Very hardcore and interesting! Can it burn a ti84+?
America 🦅
Maybe, but it'd probably be too wasteful to find out Wink
Maybe put in a Mini USB port and write a program for the 84 to have it blow for set amounts of time (1 second, 5 seconds, etc)
Haha, this is fantastic! Having stats on the calc screen would be great Very Happy
The torch burns around 2000°F which is enough to burn most objects. I really don't want to produce a bunch of toxic smoke by burning electronics though Wink
Sick! Love the paint job too. That's awesome that you were able to make this.
In order to make this a full 'calculator' flamethrower I needed to add a calculator somehow. I decided the best way was to get a Vernier temperature probe that plugs directly into the calculator, then insert the probe into the barrel of the flamethrower to monitor the internal temperature. The EasyData app displays the current temperature and can even plot it on a graph. I'll mostly be using it to ensure the barrel isn't about to melt. Laughing
(click for full size)
A water bucket and fire extinguisher were present to prevent any fire from spreading.
In this short 1 minute burn, the barrel didn't get more than 10 degrees above ambient! I'm happy to call this project complete. I might add a quick connect so it's significantly faster to attach the propane, but I'll have to investigate if it'll introduce any leaks in this configuration. I might also tweak the igniter so it's more reliable but other than that I'm quite pleased with the way it looks and operates!
This is actually legendary. Cool
What is TheLastMillennial even about at this point lmao this is so ridiculously fun. Congrats! (very original idea man) Evil or Very Mad
Small update: in the past few months and I've burned through the disposable 1lbs propane bottle which lasted me almost 30 minutes of total work. The naysayers on reddit who thought this would never work are suddenly quiet Laughing
It was able to burn all the weeds I my driveway with barely any damage! The hot glue I used to replace the broken screw inserts softened enough to let the screws slip out by the barrel. That's not hard to fix though. The heat shielding has kept any plastic from melting!
I've since painted my wall mount, bought a refillable propane bottle, and added a hook to hold the propane on the wall.
This has been really fun to bring to bonfires and the igniter has been shockingly (it's piezoelectric haha) reliable. The only modifications I still want to make are adding a bipod so the hot barrel doesn't touch the ground, and a custom adapter setup to remove 2 potential leak sources.
