I was using my calculator when suddenly it stopped registering inputs from all buttons.
I tried resetting it, and it brings me to the language select page as usual, but it still doesn't register any button inputs including the command to turn it off, so the it's stuck on the language select page.
Has anyone else experienced this issue? If so, how did you fix it if possible?
Thanks in advance.
Fixed, turns out it was water that got into the calculator.
I took it apart and dried it, and it started functioning again as normal.
Lucky you caught it before it could do more damage.
