How i can transfer .py files to my TI-Nspire CX II-T CAS?I cannot do this with TI-Nspire student software where it give me result as "Unsupported file type", how i can convert .py file to .tns or just transfer .py file to calculator?
usually, to transfer a non-tns file to an nspire you just add the ".tns" suffix to the filename.
so: for a python script named "file.py":
file.py becomes file.py.tns
hope this helps! Very Happy
Adding the extension only works for files that will have a third-party reader for that file type.
That is not the case here if you're going to use the built-in python (probable).
So what you will need to do here is actually to use the Nspire software on the computer to create a new python program in a document then paste your code in it; then transfer that tns document to the calculator
