Yes, I know and understand that rule 4 exist to prevent the server turning into creative mode where scarcity doesn't exist. However, I believe that TNT duping, as similar as it may sound to other duplication glitches, should be allowed on the server.
First and foremost, it does not actually duplicate resources. It "duplicates" TNT by creating a primed TNT entity without consuming the block. As you are unable to un-prime TNT, you cannot actually generate TNT items from this. This method cannot be applied to valuables, such as shulker boxes, as it is specific to TNT, so it wouldn't break the economy. Also, this does not duplicate items nor blocks, so the chance of getting slippery slope arguments for resource dupes is minimal.
Secondly, it is a very useful mechanic. The use of TNT duping in technical Minecraft commuities is widespread in lots of creations, such as tree farms or world eaters, which would otherwise be infeasible or impossible without TNT dupers. While wither cages exist, they often require breaking bedrock (which is an unintended bug), and bedrockless/movable cages are often unreliable, potentially releasing a wither into the wild, causing massive damage to the world. Aren't we supposed to make technical wonders in Cemetech?
Last but not least, it is officially acknowledged as a game mechanic. As you can see in https://www.reddit.com/r/Minecraft/comments/fkt9jf/comment/fkv33q3/, slicedlime, Minecraft's Java Tech Lead, acknowledges that this mechanic is intentionally left into the game, just like quasi-connectivity (which also started out as a bug and later accepted as a part of the game). Therefore, it's not just an unintended exploit.
You may ask, "wouldn't TNT dupers allow griefers to easily destroy large bases with ease?" Even though it has major destructive potential, it's not an easy way to grief, as they require lots of slime blocks and dead coral fans. Slime blocks are difficult to acquire in large amounts without a farm in a slime chunk (which is a big undertaking in and of itself), and dead coral fans require a silk touch pickaxe to get. So, it is not a big issue for potential abuse.
In conclusion, the benefits of allowing TNT duplication massively outweighs the disadvantages of allowing it, therefore I propose that it shall be placed under an exception to rule 4.
Comments are welcome.
