- TI-81 Hardware and ROM Versions
- 13 May 2015 06:22:34 pm
- Last edited by CVSoft on 01 Sep 2017 04:10:04 pm; edited 1 time in total
As many people know, I have extended my work with documenting the hardware and ROM versions of the TI-82 over to the TI-81, and my current findings are published here. Throughout the research, I purchased three TI-81s: 0719871 I-0790, ROM 1.1; 1210793 I-1292 'B', ROM 1.8K; and 0804828 I-0893 'D', ROM V2.00. I targeted the undumped ROM versions to add to my collection; ROM dumps can be expected in the next few months after this initial posting.
Hardware Versions
There are at least 7 distinct variations of the TI-81, each with a unique external physical appearance:
I have taken comparison pictures of my own TI-81s: the backup battery area between the first and fourth variants, the texture of the display bezel between the first and fourth variants, the printing on the display bezel between the first, fourth, fifth, and sixth variants, the serial number area between the first and fourth variants, and the [ON] button area between the first and fourth variants.
ROM Versions
Eight ROM versions are known, dumped versions are in bold:
Very early TI-81s, along with at least one produced in December 1990, use ROM 1.0. Version 1.1 is uncommon, and is present in both known July 1990-produced TI-81s. Shortly after 1.1, 1.1K was introduced and is common towards the end of 1990. Around March 1991, ROM versions 1.5K and 1.6K were introduced. 1.8K is paired with hardware revision 'B'; V2.00 was introduced when the plastic color changed to dark blue, and V2.0V was introduced alongside the 1993 screen bezel redesign.
Hardware Versions
- The original TI-81, which began production around the beginning of 1990. As well known, these do not have a backup battery; however, these do not have a bar below the [ON] button. Additionally, the place where the backup battery should be instead contains two plastic rings (see the detailed comparisons below for a picture).
- Still in pre-'A' hardware revisions, the second variant of the TI-81 was introduced in May 1991 to prepare for the implementation of the TI-81 'A' and TI-85. A plastic bar was added below the [ON] button to prevent accidental presses. The backup battery's socket and labeling is present under a flat plastic cover, but there are no contacts under the cover.
- The third variant of the TI-81, hardware revision 'A', added a backup battery. The battery information on the back of the calculator was updated to indicate this.
- The timing coinciding closely with the release of the TI-85, the fourth variant of the TI-81 (hardware revision 'B') drastically improved the quality of the display and changed the texture of the screen cover to the even texture used in all later calculators until the TI-73. The screen was upgraded to one with viewing characteristics quite similar to the TI-85's screen, with blue-on-green pixels and a wider viewing angle. Due to a change in the contrast-setting code, these all have ROM 1.8K. This variant had a long production run, from April 1992 to sometime around May 1993.
- Unfortunately, the fifth variant of the TI-81 undid these improvements. Externally, the most evident change is the housing plastic is no longer a bluish gray but rather a dark blue. The display bezel still uses the style of the TI-85 and variant 4 TI-81s. The mold used is very similar to that of the TI-82, differing only by the missing link port. Internally, this variant (and all future ones) use TI-82 PCBs and display drivers with TI-81 RAM and ROM chips. There are a few other changes, mostly relating to the slower CPU clock (either 4 or 5 MHz vs. 6 MHz) and different RAM/ROM chips. Different pinouts are compensated for by using zero-ohm resistors to connect the correct pins. All TI-81s of this variant that were checked use ROM V2.00.
- Towards the beginning of 1994 or the end of 1993 (I am not certain due to the very poor readability of date codes on the dark plastic TI-81s) the display bezel was restyled to match the TI-82's styling, with the "TI-81" text bolder and to the right, while the TI logo was moved to the far left of the bezel labeling area. Internally, the RAM chip was changed to use a Suwa Seikosha SRM2264 in place of a Sharp LH5160N (due to a very limited sample size, this is not confirmed), and the ROM version was updated to V2.0V.
- At the beginning of 1995, the TI-81, TI-82, and TI-85 all received a cosmetic change to their display bezels. On the TI-81, the display bezel was made much narrower, the background color is the same blue color as the calculator's plastic, and all text is white. "TI-81" is no longer italicized. Internally, the PCB was updated to version 31A (also seen on the TI-82). No other internal changes were made.
ROM Versions
- 1.0
- 1.1
- 1.1K
- 1.5K
- 1.6K
- 1.8K
- V2.00
- V2.0V
