I am making a program with ICE. In this program, the player will need to type in the name of an appvar. I am wondering how to take string input in Ice.
Thanks in advance,
Flare2003
The exact same way you do it in TI-Basic:
Input "STRING",VAR
Asks for a user input while displaying "STRING", and stores the value in VAR.
(Citing https://github.com/PeterTillema/ICE/blob/master/docs/commands.html)
I tried this but when I put...
Input "string",Str1
The ICE compiler says, "you have an invalid expression" and doesn't finish compiling.
On what line does it say the invalid expression is? Maybe you have your syntax wrong. But seriously, read this page, it has all the answers: http://petertillema.github.io/ICE/commands.html
Hope you solve your issue! Very Happy
The compiler says the error is on line 25, the same line the code is on. I tried again, and it works with normal variables, but it won't work with strings.
ICE is finicky, this statement is correct.
If you want, you can convert the normal variable to a string like this:
Alloc(length(VAR)+1)→Str1
Copy(Str1,VAR,length(VAR)+1)
However, you are much less likely to have problems if you just use the normal variable to open the AppVar instead of converting it to a string.
This could help:
https://www.cemetech.net/forum/viewtopic.php?p=292258#292258
