I’m using ICE V2.2 and I have tried re-installed it a few times (just in case) and I have a Ti 84+CE. I’m able to display a sprite and everything and that works but the flip sprite is not working or I’m just not using it right. On the command list it says to do this: det(64,PTR_IN,PTR_OUT) so I have my defined sprite as C and the variable I want to be the flipped sprite E and I would do det(64,C,E) then I display E like I did C. It either resets my ram or just doesn’t work. Thanks (:
