How do you make a string of unknown length in c? I don't wanna make the char varName[500000] but I also don't want stuff cut off.
Use dynamic memory allocation. For instance reading a single line of arbitrary length from standard input:
#include <stdio.h>
#include <stdlib.h>
char *readLine(FILE *fp) {
    size_t capacity = 32;
    char *out = malloc(capacity);
    size_t len = 0;
    do {
        if (len >= capacity) {
            capacity *= 2;
            out = realloc(out, capacity);
        int c = fgetc(fp);
        if (feof(fp)) {
            len += 1;    // Match end-of-loop increment to avoid dropping a char
            break;
        out[len] = (char)c;
    } while (out[len++] != '\n');
    len -= 1;   // Fix extra increment
    out[len] = 0;
    return realloc(out, len);
int main(int argc, char **argv) {
    char *s = readLine(stdin);
    puts(s);
(Handling of memory allocation errors omitted for brevity.)
Thank you for the information! I would like to know how you pass this into a scanf? That is what I am trying to do.
You could do a similar thing but wrap getc instead if reading from stdio I guess?
Use sscanf after reading the input (at which time you know how big you need to make the buffer), or if GNU extensions are okay use the %ms specifier (assuming you want an arbitrary-length string as a result).
getc is equivalent to fgetc(stdin), so that's not very helpful. The trick is in the scanf family taking pointers to buffers to copy values to, which must be preallocated. %ms allocates a buffer for you, but it's not standard.
