This code tracks life in games like Yu-Gi-Oh and Magic. It can handle 2-4 players, and the menu will adapt to whatever the amount of players needed is. The Menu( command can be replaced with anything else, as long as it is still user friendly. I am going for the lowest size, because speed is not an issue.
ClrHome
Input "Starting Life: ",X
Repeat 2≤P and P≤4
   Input "Players: ",P
{X,X,X(P≥3),X(P=4)}→L₁
Lbl M
ClrHome
If P=2
Menu("Life Tracker","P1: "+eval(L₁(1)),1,"P2: "+eval(L₁(2)),2,"Quit",Q
If P=3
Menu("Life Tracker","P1: "+eval(L₁(1)),1,"P2: "+eval(L₁(2)),2,"P3: "+eval(L₁(3)),3,"Quit",Q
If P=4
Menu("Lifer Tracker","P1: "+eval(L₁(1)),1,"P2: "+eval(L₁(2)),2,"P3: "+eval(L₁(3)),3,"P4: "+eval(L₁(4)),4,"Quit",Q
Lbl 1
Input eval(L₁(1)),Str1
expr(toString(L₁(1))+Str1)→L₁(1)
Goto M
Lbl 2
Input eval(L₁(2)),Str1
expr(toString(L₁(2))+Str1)→L₁(2)
Goto M
Lbl 3
Input eval(L₁(3)),Str1
expr(toString(L₁(3))+Str1)→L₁(3)
Goto M
Lbl 4
Input eval(L₁(4)),Str1
expr(toString(L₁(4))+Str1)→L₁(4)
Goto M
Lbl Q
Stop
This should work, but I haven't tested it. I tested it now. I just optimized what I saw. I changed all the menus to one custom menu and replaced all your repetitive values/code with variables. This is in sourcecoder format btw I hope you don't mind
ClrHome
Repeat sum(P={2,3,4
Input "Players: ",P
{X,X,X(P>=3),X(P=4->L1
Lbl M
ClrHome
Output(1,1,"Life Tracker
For(I,2,P+1
Output(I,2,"P"+toString(I-1)+": "+eval(L1(I-1
Output(P+2,2,"Quit
2->A
Repeat sum(K={45,105
Output(A,1,">
Repeat Ans:getKey:End
Ans->K
Output(A,1,"
A+(Ans=34)(A<P+2)-(Ans=25)(A>2->A
ClrHome
If K=45 or A=P+2:Return
A-1
Input eval(L1(Ans)),Str1
expr(toString(L1(Ans))+Str1->L1(Ans
Goto M
After some minor corrections, it works great! thanks!
Oops, yeah it looks like I made a mistake or two. I just fixed the code and edited my last post for you, but you probably came up with the same thing too. You're welcome btw Smile
I made the scores be displayed in color, and added a cool display that uses the Center of Mass equation to kind of represent who is strongest. This could probably use some more optimizations now.
{11,15,14,18,10,17,13}->|LC
Degree
Menu("Life Tracker","New Game",N,"Load Game",L
Lbl N
Repeat sum(P={2,3,4,5,6,7
   Input "Players: ",P
P->dim(|LLIFE
Fill(X,|LLIFE
Lbl L
dim(|LLIFE)->P:P->dim(|LX:P->dim(|LY
StoreGDB 1
AxesOff:GridOff
0->Xmin:32->Xmax
0->Ymin:20->Ymax
BackgroundOn DarkGray
Lbl M
ClrHome:ClrDraw
TextColor(Black
Text(0,0,"Life Tracker
Text(12(P+1),10,"Quit
For(Q,1,P
   TextColor(|LC(Q
   Text(12Q,10,"P",toString(Q),": ",eval((|LLIFE(Q
0->L
For(theta,0,359,360/P
   L+1->L
   21+P>Rx(8,theta->|LX(L
   10+P>Ry(8,theta->|LY(L
(Sigma(|LX(L)|LLIFE(L),L,1,dim(|LX)))n/d(sum(|LLIFE->A
(Sigma(|LY(L)|LLIFE(L),L,1,dim(|LY)))n/d(sum(|LLIFE->B
For(L,1,P
   Pt-On(|LX(L),|LY(L),|LC(L
   Pt-On(|LX(L),|LY(L),2,|LC(L
   Line(|LX(L),|LY(L),A,B,|LC(L),1
Pt-On(A,B,|LC(1+sum(not(cumSum(|LLIFE=max(|LLIFE
Pt-On(A,B,2,White
1->A
Repeat K=105
   TextColor(Black
   Text(12A,0,">
   Ans->K
   Text(12A,0,"
   A+(Ans=34)(A<P+1)-(Ans=25)(A>1->A
If A=P+1:Goto Q
ClrHome
A
Input eval(|LLIFE(Ans)),Str1
max(0,expr(toString(|LLIFE(Ans))+Str1->|LLIFE(Ans
Goto M
Lbl Q
RecallGDB 1:BackgroundOff
