I am creating the following eZ80 assembly function, callable from a C program:
   public _setbit
_setbit:
; Sets pos bit of byte if not set; resets bit if set
; Arguments:
;   arg0 = uint8_t *byte
;   arg1 = uint8_t pos
; Returns:
;   True if bit set; false, if bit reset
   call    _chkbit      ; Returns state of bit in a
   pop     hl
   pop     de   ; de = byte pointer
   pop     bc   ; bc = pos
   push    bc
   push    de
   push    hl
   ld      b, c
   inc     b
   ld      c, 1
.shift_left:
   sla     c
   djnz    .shift_left        ; After this loop completes the bit in e
                              ; will be at pos
   xor     a, 0
   jr      z, .setbit
   ld      a, (de)            ; Load byte into a
   sub     a, c               ; If bit is set, reset it
   ld      (de), a            ; Load the changed byte back into the original addr
   xor     a, a
   ret
.setbit:
   scf                   ; dbg_Debugger();
   sbc     hl, hl
   ld      (hl), 2
   ld      a, (de)
   add     a, c
   ld      (de), a
   sbc     hl, hl
   ld      (hl), 2
   ld      a, 1
   ret
Here is the code for _chkbit:
   public _chkbit
_chkbit:
; Checks the pos bit of byte
; Arguments:
;   arg0 = uint8_t byte
; Returns:
;   True if bit set; false, otherwise
   pop     hl   ; hl = stack pointer
   pop     de   ; de = byte
   pop     bc   ; bc = pos
   push    bc
   push    de
   push    hl
   ld      b, c   ; Load pos into b
   inc     b
.shift_right:
   srl     e
   djnz    .shift_right
   jr      nc, .false
   ld      a, 1
   ret
.false:
   xor     a, a
   ret
And the main.c:
#include <stdint.h>
#include <stdbool.h>
#include <math.h>
#include <debug.h>
bool chkbit(uint8_t byte, uint8_t pos);
bool setbit(uint8_t *byte, uint8_t pos);
void main(void) {
   uint8_t byte = 1;
   uint8_t pos = 1;
    dbg_sprintf(dbgout, "chkbit returns %d\n", chkbit(byte, pos));
   dbg_sprintf(dbgout, "setbit returns %d\nbyte = %d", setbit(&byte, pos), byte);
   return;
My problem is that the assembly function is not altering the value of byte, making it return the same value every time the program is run. How do I correct this?
On a side note, I am sure that this is probably nowhere near the most efficient algorithm for doing these functions. I would greatly appreciate any tips to make these two functions more efficient 🙂
EDIT: @Beckadam: I replaced the code in _chkbit with your code:
   pop     bc   ; c = byte
   pop     de   ; e = pos
   push    de
   push    bc
   push    hl
   ld   a, e   ; Load pos into a
   rla
   rla
   rla
   add   a, $C1
   ld   (smc), a
   set   0, c
smc:=$-1
   ret
It doesn't work for some reason, however. I am still not quite sure how the ld (smc), a works. Could you explain, please?
There's no sequence point. Move the setbit function outside of the dbg_sprintf call. The compiler pushes the current value of byte, calls the setbit function, pushes the return value, pushes some other stuff, calls dbg_sprintf, and returns.
