- Modding my CE w/ Backlight, Speaker, and Wireless Charging!
- 05 May 2020 08:37:41 pm
- Last edited by TheLastMillennial on 04 Jan 2022 07:02:31 pm; edited 8 times in total
I've been tossing some ideas around that would add unnecessary, but neat features to my TI-84 Plus CE!
Finished: My first one would be to triple the CE's battery life. How? By add two additional batteries! With some preliminary measurements, I found out the shell is *just* deep enough (5mm) to add at least one battery in over the ASIC and flash if I file down some structural bits in the shell (squared in red). I'm not sure if I can fit another over the LCD. The shell is 3mm deep and the foam is 2mm which theoretically means I can fit a battery there, but I'm not sure if I can take off the foam without damaging the LCD? I'll also need to find a way to reliably connect the batteries together without the connections being loose.
(click for full size)
Finished: My second idea would be to add a wireless charging receiving pad to the inside of the shell. I haven't really done any measurements for this yet but it looks like even with the extra batteries I could still cram in such a thin device. Since the shell is just plastic, there shouldn't be much interference. All I would need to do is cut off the micro USB end and solder the power leads to the mini USB connector of the calculator. I wonder if there would be issues though if I plugged a cable into the calculator while it was wirelessly charging?
Finished: My third idea would require quite a lot of work and frankly I'm not sure I want to go though with it. It's such a good idea though, back-lighting the keys!
Finished: My fourth idea was to add a bluetooth speaker to the calculator. Since I now have the second battery inside the calculator, I can take out the original battery and use the battery bay for small, isolated projects. I want to be able to make a phone call through my calculator!
So, yes, lots of work. I'd love to hear your input though! Someone always has knowledge I don't about hardware modification and I'm willing to hear even the worst news.
- I'd be fitting the LEDs between the plastic key and the rubber membrane
- I would need to find some low power LEDs that are small enough to even fit in the top 5 keys and arrow keys, but still bright enough to illuminate my denim colored plastic.
- The battery hit from turning on all those LEDs may require the battery mod from idea one.
- I would need an off switch somewhere because I'd be hooking the LEDs directly to the battery terminals. Probably removing one of the charging dock contacts at the bottom would be the best place.
- I need wire thin enough it doesn't interfere with the keys.
- I need to be sure the wire is insulated somehow so it doesn't accidentally short and cause big issues.
- Due to the size of the led inside the plastic button, I may need to file down the rubber membrane to compensate and avoid false button presses (can I even do that?).
