I started a new game called The Adventures of a Mustard Cat. I plan to have a randomly generated open world map where you explore and collect stuff to become stronger. The story/objective of the game will be something along the lines of you, a cat from the mustard realm, are stranded in a different realm and need to make your way home to the mustard realm. You must travel through other realms with each realm being more dangerous than the last until you make it back home. Each realm will have different blocks and enemies matching its theme.
So far I have how blocks will be handled completed. Here is a list of what is done with blocks:
-collision
-durability
-special effect: Each block can have 2 special effects that are activated when standing on it, but standing on multiple blocks of the same type will not duplicate the effect.
-What it drops when broken and a min and max amount dropped
-All of the above are easily moddable
Screenshot:
Once the mod is loaded in the screenshot water, cobble, and lava are changed to have different effects and collision but the other blocks stay the same.
I don’t know how long until I will have this in a playable state, but I'm making a post anyways because otherwise I know I will forget about it. I will try to have a beta in the next few weeks when I have the first realm finished but school is about to start again so I may not be able to work on it very much.
-collision
-durability
Screenshot:
