Waver CE
by epsilon5
A small project of mine that I completed earlier today. It took about three days to reach its current state, but hopefully it will be enjoyed by the Cemetech community for longer than that. Here's Waver CE!
Inspired by the wave mode in Geometry Dash, Waver CE tasks the player with dodging boxes that randomly appear from the right of the screen. Modifiers also appear, making the slope of your line higher or lower, or even reversing gravity. As you play, the speed of the program increases, inevitably leading to a loss.
The game features several customization features, allowing you to change the color of your player, the background color, and the color of the obstacles. Your colors are all saved, meaning that you don't have to reset them each time you run the program.
Finally, Waver CE includes a few options that can improve your game experience, accessed from the settings menu. You can disable or enable the opening animation and toggle on and off the FPS meter. You can also choose to reset your high score from this menu.
FAQs
Q: When can I download Waver CE?
A: As soon as it is accepted into the archives.
Q: Did this take time away from the development of DR1VE?
A: Not significantly. As mentioned earlier, this was a very quick project. Also, this will probably end up saving me time in the long run, since I figured out how to do several things that will be helpful in the development of DR1VE.
Q: What language is it in?
A: It is written in ICE for the TI 84 Plus CE.
Q: How does it run on the calculator?
A: It runs very well, getting from between 50-55 FPS. However, the gameplay experience will be significantly worse on CEMU, since it tends to run slower and lacks physical keys. This is best played on calc.
Screenshot
That's all. I hope you enjoy Waver CE!
by epsilon5
FAQs
Screenshot
