Hi, first of all I'm very new to programming (definitely on a calculator).
I'm making a program where you have to choose 1 or 2 in the beginning.
I want to make it like if you put 1, you Goto lbl 1 and do stuff, and the same with 2.
But I think Lbl only uses the command right next to it. While I need a chain of commands.
Does anyone know how to do this?
kind regards
Stoeptegelkip
Lbl just jumps to a location in your program and resumes execution from there:
http://tibasicdev.wikidot.com/lbl
Welcome to Cemetech
What does your code currently look like?
Labels basically move execution to that point, so
Code: Goto 1
(other code)
Return
Lbl 1
Disp 1
Disp 2
Disp 3
Return
would print out 1 2 3
If you are not using the built-in Menu( command (which I recommend you do use) you might want to use If( statements instead of Gotos. For example,
Code: Input A
If A=0
Then
Do stuff
Else
If A=1
Then
Do other stuff
Thank you both for the fast and great response! 😁
I forgot to put in 'Then' after 'If A=1', after putting it there my program works perfectly!
<3
Also, "Return" quits the program entirely unless the program itself was ran from another program.
