Is the copy-from-archive thing there too?
Nope, I'm working those features into the beta I will be releasing in the near future of the beta after that. I've got it working for BASIC programs but haven't implemented it for all the various flavors of ASM programs yet.
Sorry I didn't work on the cursor sprite thing today. I was very busy. I can probably finish it tomorrow night.
As promised I finished debugging and it looks good. It's up to you, Kerm, to fit this into DCS, but I can help and explain any part of my code as needed. Also, there may have been a few optimizations (or more than a few...I've been busy) that have slipped by, but I'm confident that it does the job.
It comes in under the 700-800 byte range at 646 bytes with the stupid MOS header and the masked sprite routine. The size of the program without them is about 100 bytes less (which is what it will take up in DCS) w00t!
Before I give you the code, here is a screenie:
Pretty sweet, right?
Well, to sum up what it does:
-x2 zoom for easier sprite making
-Toggles between 3 states with 2nd (white opaque, black opaque, and white transluscent)
-Dispays white opaque as white, black opaque as black, and white transluscent as grey (that's right, greyscale!)
-User presses enter to return from the routine
-Outputs a 16 byte masked sprite (with mask first) at AppBackUpScreen
-Only uses 20 bytes of AppBackUpScreen (Your welcome, Kerm)
And without further ado:
Kerm, if you would prefer to have me ftp the code or send it to you some other way, just say so.
Comments?
;Author: Patrick Stetter
;Program: DCS Mouse Creator
;Date 7/9/06
#include "ti83plus.inc"
#include "mirage.inc"
MouseMask .equ AppBackUpScreen
Mouse .equ AppBackUpScreen+8
X .equ AppBackUpScreen+16
Y .equ AppBackUpScreen+17
GStimer .equ AppBackUpScreen+18
Blinktmr .equ AppBackUpScreen+19
.org $9d93
.db $BB,$6D
ret
.db 1
.db %00000000,%00000000
.db "Mouse Creator",0
xor a
ld (X),a
ld (Y),a
ld (GStimer),a
ld hl,MouseMask
ld (hl),0
push hl
pop de
inc de
ld bc,15
ldir
call displayOuterEdge
mainLoop:
ld hl,GStimer
inc (hl)
inc hl
inc (hl)
call displayGrid
call displayCursor
call fastcopy
bcall(_getcsc)
cp skup
jr nz,notMoveUp
ld a,(Y)
or a
jr z,mainLoop
dec a
ld b,1
jp CursorMove
notMoveUp:
cp skdown
jr nz,notMoveDown
ld a,(Y)
cp 7
jr z,mainLoop
inc a
ld b,1
jp CursorMove
notMoveDown:
cp skright
jr nz,notMoveRight
ld a,(X)
cp 7
jr z,mainLoop
inc a
ld b,0
jp CursorMove
notMoveRight:
cp skleft
jr nz,notMoveLeft
ld a,(X)
or a
jr z,mainLoop
dec a
ld b,0
jp CursorMove
notMoveLeft:
cp sk2nd
jp nz,notChangePixel
;Calls
modPixelStatus:
;White Opaque, Black Opaque, White Trans
;If White Opaque:
;-Change Mouse
;If Black Opaque
;-Change Mouse
;-Change MouseMask
;If White Trans
;-Change MouseMask
ld a,(Y)
ld hl,Mouse
ld e,a
ld d,0
add hl,de
ld a,(X)
ld b,a
ld a,7
sub b
inc a
ld b,a
ld a,(hl)
getPixelLoop:
srl a
djnz getPixelLoop
jr c,pixelIsBlack
ld a,(Y)
ld hl,MouseMask
ld e,a
;d = 0
add hl,de
ld a,(X)
ld b,a
ld a,7
sub b
inc a
ld b,a
ld a,(hl)
getPixelLoop2:
srl a
djnz getPixelLoop2
jr c,pixelIsTransparent
;White Opaque
ld a,(Y)
ld hl,Mouse
ld e,a
;d = 0
add hl,de
ld a,(X)
or a
jr z,skippixelOpaqueLoop
ld b,a
ld a,%10000000
pixelOpaqueLoop:
srl a
djnz pixelOpaqueLoop
skippixelOpaqueLoopBack:
xor (hl)
ld (hl),a
jp mainLoop
skippixelOpaqueLoop:
ld a,%10000000
jr skippixelOpaqueLoopBack
pixelIsBlack:
;Black Opaque
ld a,(X)
or a
jr z,skippixelBlackLoop
ld b,a
ld a,%10000000
pixelBlackLoop:
srl a
djnz pixelBlackLoop
skippixelBlackLoopBack:
xor (hl)
ld (hl),a
ld a,(Y)
ld hl,MouseMask
ld e,a
;d = 0
add hl,de
ld a,(X)
or a
jr z,skippixelBlackLoop2
ld b,a
ld a,%10000000
pixelBlackLoop2:
srl a
djnz pixelBlackLoop2
skippixelBlackLoop2Back:
xor (hl)
ld (hl),a
jp mainLoop
skippixelBlackLoop:
ld a,%10000000
jr skippixelBlackLoopBack
skippixelBlackLoop2:
ld a,%10000000
jr skippixelBlackLoop2Back
pixelIsTransparent:
ld a,(X)
or a
jr z,skippixelTransLoop
ld b,a
ld a,%10000000
pixelTransLoop:
srl a
djnz pixelTransLoop
skippixelTransLoopBack:
xor (hl)
ld (hl),a
jp mainLoop
skippixelTransLoop:
ld a,%10000000
jr skippixelTransLoopBack
notChangePixel:
cp skenter
ret z
jp mainLoop
displayOuterEdge:
;displays 4 black lines surrounding our grid.
ld hl,39*256+23 ;(23,39) (23,56)
push hl ;-------------
ld d,56 ;| |
ld e,l ;| |
push de ;| |
ld a,1 ;| |
call fastline ;-------------
pop de ;(40,39) (40,56)
ld hl,56*256+40
push hl
ld a,1
call fastline ;doesn't say what's destroyed. Assume all.
pop hl
ld de,39*256+40
push de
ld a,1
call fastline
pop de
pop hl
ld a,1
call fastline
ret
displayGrid:
;Displays the current state of pixels
ld b,8
ld hl,Mouse-1
ld e,22
GridOuterLoop:
push bc
inc hl
ld a,38 ;2 less than what it will display first at
inc e
inc e
ld b,%10000000
GridInnerLoop:
push bc
push hl
push de
push af
ld a,(hl)
and b
jr z,GridDisplayBlank
GridBlack:
pop af
pop de
inc a
inc a
push de
push af
ld l,e
ld b,2
ld ix,Block
call iPutSpriteMask
jr DisplayGridJoin
GridDisplayBlank:
ld de,8
or a
sbc hl,de
ld a,(hl)
and b
jr nz,GridDisplayGrey
GridDisplayBlank2:
pop af
pop de
inc a
inc a
push de
push af
ld l,e
ld b,2
ld ix,Blank
call iPutSpriteMask
DisplayGridJoin:
pop af
pop de
pop hl
pop bc
srl b
jr nz,GridInnerLoop
pop bc
djnz GridOuterLoop
ret
GridDisplayGrey:
ld a,(GStimer)
srl a
jr c,GridDisplayBlank2
jr GridBlack
Block:
.db %00111111
.db %00111111
Blank:
.db %00111111
.db %00111111
Dummy:
.db 0,0,0,0, ;4 bytes of crap
BlockMask:
.db %11000000
.db %11000000
BlankMask:
.db %00000000
.db %00000000
displayCursor:
;flashes cursor at X,Y
ld a,(Blinktmr)
cp 20
jr nc,CursorBlinkOff
CursorOn:
ld ix,Block
displayCursorBack:
ld a,(Y)
add a,a
add a,24
ld l,a
ld a,(X)
add a,a
add a,40
ld b,2
call iPutSpriteMask
ret
CursorBlinkOff:
cp 40
call nc,resetBlinktmr
CursorOff:
ld ix,Blank
jr displayCursorBack
resetBlinktmr:
xor a
ld (Blinktmr),a
ret
CursorMove:
;Makes it blank at last spot
;Makes it solid at next spot
;b = 0 lr, b = 1 ud
push af
push bc
xor a
ld (Blinktmr),a
call CursorOff
pop bc
ld a,b
or a
jr z,CursorMoveLeftRight
pop af
ld (Y),a
call CursorOn
jp mainLoop
CursorMoveLeftRight:
pop af
ld (X),a
call CursorOn
jp mainLoop
; Ion Extended Routines by Joe Wingbermuehle and Kerm Martian
;Inputs: Exactly the same as iPutSprite, but with 16 bytes at ix.
iPutSpriteMask:
ld e,l
ld h,$00
ld d,h
add hl,de
add hl,de
add hl,hl
add hl,hl
ld e,a
and $07
ld c,a
srl e
srl e
srl e
add hl,de
ld de,gbuf
add hl,de
iPutSpriteLoop1Mask:
ld d,(ix)
ld e,$FF
ld a,c
or a
jr z,iPutSpriteSkip1Mask
iPutSpriteLoop2Mask:
srl d
rr e
set 7,d
dec a
jr nz,iPutSpriteLoop2Mask
iPutSpriteSkip1Mask:
ld a,(hl)
and d
ld (hl),a
inc hl
ld a,(hl)
and e
ld (hl),a
push ix
dec hl
ld de,8
add ix,de
iPutSpriteLoop1AND:
ld d,(ix)
ld e,$00
ld a,c
or a
jr z,iPutSpriteSkip1AND
iPutSpriteLoop2AND:
srl d
rr e
dec a
jr nz,iPutSpriteLoop2AND
iPutSpriteSkip1AND:
ld a,(hl)
xor d
ld (hl),a
inc hl
ld a,(hl)
xor e
ld (hl),a
pop ix
ld de,$0B
add hl,de
inc ix
djnz iPutSpriteLoop1Mask
ret
.end
end
Comments?
Didn't you see my response in SAX? I think it's uber1337. Nicely done, and I'm very impressed. i'll be integrating it tomorrow probably.
Oh, I thought you were going to make a post in the topic, and just forgot.
Do I get my name in the credits or something, now? That'd be sweet
lol, if I get my name in as a beta tester, I would hope you would get yours in as an assistant programmer...
Of course you get your name in the credits!
Watch the alpha cursor closely at the beginning and end of this clip:
this is coming along nicely. Still planning to have done be New Years Eve, or has that date been pushed up a little?
Still planning for New Years' Eve to save disappointment if I can't finish early. Here's a new screenie for everyone:
Custom mouse!
Indeedy. I have posted a separate topic about it to try to get this part of the topic back ontopic. (Did I say topic enough in that sentence? Topic topic topic I wonder topic what the topic of the topic might topic be).
Next I will be releasing a beta, so that should come today or early tomorrow.
Well, I've been meaning to do this for a while, but I finally got around to respacing the icons on the desktop, the work of about 4 minutes tops. Check it out below; what do you think, better or worse?
Interesting, but aren't those icons bigger? If so, maybe include and option to change the icons per page between 6 and 12.
No, those are still start 16x16 icons. Fitting 12 would not be pratical unless I create a list view, since 8x8 icons are not part of the current paradigm.
Ok, hmmm... I seem to remember something about 12 icons per page...
Page 5 of 6
